2007 F150 5.4L- windshield Washer fluid clogged - Ford Truck Enthusiasts Forums
Old 03-06-2014, 10:40 AM
shockr4's Avatar
shockr4 shockr4 is offline
shockr4 is starting off with a positive reputation.
The wind shield washer fluid has stopped coming out on the driver side. It just barely trickles out. It still comes out fine on pass side. Is there some type of fluid I can add that will open up the line assuming there is corrosion or something block it? Or should I stick a pin into the nozzle to clear it?
Thanks
Old 07-01-2014, 10:58 PM
rlpaulk78 rlpaulk78 is offline
rlpaulk78 is starting off with a positive reputation.
not sure if you still have the problem or not but I wouldn't stick anything in the nozzle (might mess up the spray pattern). on my 05 lariat screw the rubber seal for the windshield washer pump deteriorated and clogged my nozzles. took the nozzles off & blew out with compressed air, changed the pump & seal. no more clogging
Old 07-02-2014, 04:08 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
I had an SUV that clogged frequently. I learned to disconnect the supply hose from the pump to the nozzles and blow into the nozzles with compressed air. You can usually find a plastic union at a convenient place in the firewall/cowl area. Definitely don't stick anything into the nozzles. After clearing them, you might run the pump to clear any other debris in the lines before connecting the supply. Check out the reservoir and clean it as required. I guess if you don't have air at home you could try a dust-off can with the straw attached. You can also use a Water Pik at full strength if you have one of those. Whatever you use in this method, the supply line has to be open so the air, water and debris have somewhere to go.
Old 07-02-2014, 05:31 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
This is good advice ,if you DO have to clear it out , I used a single wire from a wire brush (a new one) and it didn't wallow out the spray hole .
Washer Fluid Leak Ex03AK Excursion - King of SUVs 16 01-07-2017 05:59 PM
Windshield washer fluid leak Hitagain Excursion - King of SUVs 6 01-05-2017 07:15 PM
windshield washer reservoir fordboy300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 03-13-2015 07:38 AM
Windshield wiper fluid leak expy37at 1997-2006 Expedition & Navigator 8 06-05-2014 09:28 AM
Windshield washer fluid Chris 56 f6 1999 to 2016 Super Duty 9 02-06-2013 07:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
