later model dana 60 in 78-79 ford
Late model...how late? Like a closed knuckle, disk brakes cheap D60? Bad idea IMO like these...
74-75.5 Ford low pinion drivers side closed knuckle drum brake with 30 spline inners, 19 spline outers, small ujoints and weak knuckles.
75.5-77 Ford low pinion drivers side open knuckle disc brake 30 spline inners, 19 spline outers, outer knuckle spindle pilot hole is smaller than 78+ axle and is therefore notched to allow 1480 series U-joint tp pass through.
Here you go, to help get smart on what to shop for D60 wise and spend your money right.
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Spring pad width info is in there also.
csangster
05-27-2004 12:22 AM
