F100 front Dana 44 fit rear?? - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 03-05-2014, 02:52 AM
Dave 64 Dave 64 is offline
Dave 64 is starting off with a positive reputation.
Hi, Another general purpose question. Ripped a 1976-1980 F100 4X4 FRONT end apart for the brake set up and whilst I was at it, took the Dana 44 3.5:1 Crown wheel and pinion, in excellent nick. Have a LSD Dana 44 REAR here as well with a few noises, 3.73:1 so was wondering if the Ford front CW & P will fit into the rear 44? Believe it is NOT the HP version, anyway of telling by the Dana numbers stamped on the rim of the crown wheel? Not having a great deal of luck with Dana numbers for some reason, maybe not asking in the right forum section?? BTW, using it in 2WD vehicle!
Cheers, Dave 64
Old 03-05-2014, 01:32 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Dave, this page has a lot of useful info: Mr.N's Dana Articles to Include 44, 60 information.
Specifically this page: Dana 44 Solid Front Axle: Reverse Spiral and Standard Housing info..
The front D44 should be a High Pinion one. All F100 front axles from 1966+ had D44HP's to my knowledge. This means that the pinion and ring gear are cut in the opposite direction and aren't transferable to the rear axle.
Old 03-05-2014, 03:45 PM
Adrian,
Thanks for that. Just my luck, thought it was too good to be right!
No drama, I'll probably advertise it or see if I can do a deal with the differential repair guy and trade it in.
Cheers, Dave
Old 03-05-2014, 04:36 PM
You should be able to sell it easily. A complete D44 HP from the year range you mentioned is a very desirable front axle, particularly for the Jeep crowd.
Dana 44 disc brake swap ungerp 1973 - 1979 F-100 & Larger F-Series Trucks 19 10-12-2014 10:58 PM
Couple of questions? Dave 64 1967 - 1972 F-100 & Larger F-Series Trucks 9 09-16-2014 10:25 PM
Trying to locate original part numbers Dave 64 Australia Chapter 0 03-04-2014 03:07 PM
6 or 8 stud wheels?? Dave 64 1967 - 1972 F-100 & Larger F-Series Trucks 12 02-07-2014 04:24 AM
Dana 44 IFS spb78 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-13-2003 05:04 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
