temp sensor
temp sensor
OK so was helping brother work on his 95 ,new to him ps....The temp gauge is way past the white on the cold side.....so we changed the one in the waterpump....and nothing
...is there another one......and was working on the horn......fuse is good but now power to the horn.....and no power under the steering wheel......have I told you how.much I hate wireing...thanks guys
I have the same problem on my sc. I believe the sensor on top of the pump is for the guage at the dash from my memory of trying to fix my problem.. I hear ya about disliking wiring..I'm right there with ya..but if you figure anything out I'd be stoked to know!! Good luck!!
Disconnect the sensor and ground the wire for it. Turn the key to RUN. Either the gauge should peg all the way right, or the ENGINE TEMP light in the diesel-specific panel should light up. Then do the same with the other sensor/wire. That will tell you which one is for the light and which is for the gauge. If one of them pegs the gauge, then the gauge head is good and that sensor is bad. If neither one pegs the gauge, then the gauge head is bad, which is not uncommon. The temp gauge and oil pressure "gauge" are together in one head unit. LMC has them, or you could scavenge one from a junkyard truck.
TheGageinator
08-13-2013 05:58 AM
Bikedude987
06-05-2012 10:40 PM
chefrobert
1983 - 2012 Ranger & B-Series
03-26-2007 10:06 PM
