Bought One, Now a few Q's - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-04-2014, 06:06 PM
aj197816134 aj197816134 is offline
aj197816134 is starting off with a positive reputation.
Bought a 2006 E -250 with the 5.4 and 161,000 miles on it. Clean van, just needs some TLC and PM.
3.73 Rear End
Van, runs and drives pretty nice, a little sway, but thinking some is in the tires and perhaps needs some Tie Rods etc.
Questions:
Can I switch the 225 75 16 Tires, to 245 75 16?
Have the 245's from my 1 ton
I heard an ever so faint knock when idling, and it disappeared as soon as any throttle was given, seemed to dissipate after I ran it. Thinking and oil change is first. I know there is the normal triton sounds.
I WILL Be picking the van up on Friday, So I know I have some looking and thinking time! I have a pretty complete list of the service history coming with it as well, so I can see what was done, and what needs addressed.
list, Prioritized
Lube, oil and Filter
Check Front End
Spark Plug last changed, or changed (fingers crossed here)
Old 03-05-2014, 07:14 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Your new van seems a quite like one I bought in 2012---it's an '03 extended body E250, had 165K miles at the time. PO was a trucking company with in-house mechanic who kept decent records since it was new to them.
245's should fit without too much problem---I'm running them on another E250 I have. If front springs are a bit weak on hard bumps the fenders might bump against the tires but nothing severe. Turning won't be an issue either.
The slight knock at idle needs to be monitored at best----at this point if its a deep in the engine problem not a lot to be done apart from rebuilding it. I doubt that's necessary so don't worry too much about that.
When changing oil make sure to use the same viscosity as the PO has used during their ownership. Heed the viscosity because that motor absolutely demands adherence to the factory recommendations.
Plugs can be a challenge but they're not horrible to change, NEVER let them go much past 50-60K miles though; despite claims they're good for 100K miles they're really not. Easily changed, not that expensive makes this one of the least complex maintenance steps on our vans.
Your sway issues could be any number of things but once you have the front suspension inspected let us know what's what there. Vans in general might seem to sway or move around while in motion more so than other vehicles, that can take a short while to acclimate to their unique handling characteristics.
Hope to see some photos of the newbie!
Old 03-05-2014, 08:46 AM
Here are the PLUS Sides
I own a garage, so putting on the lift shouldn't be as challenging. I am very picky with my own vehicles, just like with customers. My dad and myself bought a 1995 E 350 back in 2001 and I am just having to retire her now! The 5.8 RUNS GREAT still, but the body to say the least is gone. I worked that truck over and over, filled her full of firewood stacked and wet, and drove where ever.
This van will be a service van, and I will put some miles on it. Good thing is I have all the service records coming with it, so I will get a chance to really examine what was done.
I will get some photos up this coming weekend, I expect a little TLC, but when I paid under 4K for it, I really cant complain much
Upsizing my tires on my 2006 E-150 - NEED HELP!!! PITMASTER 1968-2013 Full Size Vans 17 07-20-2016 06:24 PM
Using different size tires on an E-350 van - drawbacks? geoffhazel 1968-2013 Full Size Vans 14 03-15-2015 05:36 PM
2011 E-350 Tire Size Help Needed moto377 1968-2013 Full Size Vans 4 07-02-2014 07:38 PM
Wheel choices on a 99 E-350 Diesel parnellijonesvan 1968-2013 Full Size Vans 36 09-25-2013 09:37 PM
Wheel choices on a 99 E-350 Diesel parnellijonesvan Brakes, Steering, Suspension, Tires, & Wheels 4 09-13-2013 01:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
