F-sd 4x4 conversion
#33
A. put the factory dually hub on then the 8 to 10 bolt adapter then the tire
OR
B. Had the 8 to 10 lug adapter machined big enough that he could of Just bolted that to a SRW axle then bolted the tire on
#34
I had some 8 to 10 lug dually adapters machined so we could run the correct wheels.
<a href="http://s1081.photobucket.com/user/coreylasalle/media/fte/Joshs%20F-sd/0206142030a_zpsccc1ecae.jpg.html" target="_blank"><img src="http://i1081.photobucket.com/albums/j359/coreylasalle/fte/Joshs%20F-sd/0206142030a_zpsccc1ecae.jpg" border="0" alt=" photo 0206142030a_zpsccc1ecae.jpg"/></a>
The Dana 60 is from a '99.5 - '04 Super Duty, which has a different lug pattern than the OBS.
Notice the adapters, the 10 lug pattern is smaller than the 8 holes that bolt it to the axle.
The OP used '99 - '04 Super Duty F-550 dually adapters (and Dana 60 axle) because they use a larger pattern 8 lug mount (220 mm?). I have a set here from a E-550 I am hanging onto for some reason, so that's what it looks like to me.
Then he had the 10 lug adapters made to fit the '99.5 - '04 550 dually adapters.
Just my opinion from the looks of the above pic.
Edit: Then again, there's no way those adapters would fit behind the F-450 wheel, so I'm back to scratching my head again...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
#35
Here's what I think:
I know this because I have a set of these adapters in my basement lol
#36
#38
The 10 lugs on the adapter are smaller than the 8 holes.
The 8 holes bolt in place on the oem hub.
So the 8 holes/lugs must be waaaay larger ring than 8x6.5??
__________________
#39
Those two rings/Plates get bolted together.
The BOTTOM plate has the 8x6.5 bolt pattern in it, with some of the bolt holes covered up. The holes are large so you can run a lug nut onto the studs with a socket.
The holes that run along the outside of the rings/plates are just for securing both plates together as ONE adapter then.
#41
Look at the RING/PLATE below the Top Ring/Plate.
What a dumb way to do it.
__________________
#43
#45
