F-sd 4x4 conversion
Old 11-21-2014, 11:11 PM
fordpride's Avatar
fordpride
fordpride is offline
Looks good. Nice work
  #32
Old 11-22-2014, 06:38 AM
Weareweird69's Avatar
Weareweird69
Weareweird69 is offline
Well yeah I know that. Just confirming is all.
He basically made the same adapters I have sitting in my basement
  #33
Old 11-22-2014, 06:51 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by dougbrown
Yes he had to. That the only way he could run a dually tire up front.
No, he could of.....
A. put the factory dually hub on then the 8 to 10 bolt adapter then the tire
OR
B. Had the 8 to 10 lug adapter machined big enough that he could of Just bolted that to a SRW axle then bolted the tire on
  #34
Old 11-23-2014, 07:04 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Originally Posted by coreylasalle
I had some 8 to 10 lug dually adapters machined so we could run the correct wheels.
<a href="http://s1081.photobucket.com/user/coreylasalle/media/fte/Joshs%20F-sd/0206142030a_zpsccc1ecae.jpg.html" target="_blank"><img src="http://i1081.photobucket.com/albums/j359/coreylasalle/fte/Joshs%20F-sd/0206142030a_zpsccc1ecae.jpg" border="0" alt=" photo 0206142030a_zpsccc1ecae.jpg"/></a>
Here's what I think:
The Dana 60 is from a '99.5 - '04 Super Duty, which has a different lug pattern than the OBS.
Notice the adapters, the 10 lug pattern is smaller than the 8 holes that bolt it to the axle.
The OP used '99 - '04 Super Duty F-550 dually adapters (and Dana 60 axle) because they use a larger pattern 8 lug mount (220 mm?). I have a set here from a E-550 I am hanging onto for some reason, so that's what it looks like to me.
Then he had the 10 lug adapters made to fit the '99.5 - '04 550 dually adapters.
Just my opinion from the looks of the above pic.
Edit: Then again, there's no way those adapters would fit behind the F-450 wheel, so I'm back to scratching my head again...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
  #35
Old 11-23-2014, 07:46 AM
Weareweird69
In the photo, the OUTSIDE bolt pattern around the edge is how you bolt the Front plate, with the 10 lug pattern, to the Back plate, with the 8 lug pattern, together.
I know this because I have a set of these adapters in my basement lol
  #36
Old 11-24-2014, 06:48 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
So the 10 bolt F-Super Duty lug pattern is actually that much smaller than the 8x6.5 OBS pattern?
__________________
  #37
Old 11-24-2014, 07:02 AM
Weareweird69
The F-superduty is 10x7.25.
It's not much larger than the 8 lug trucks
  #38
Old 11-25-2014, 06:08 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
I am really confused now.
The 10 lugs on the adapter are smaller than the 8 holes.
The 8 holes bolt in place on the oem hub.
So the 8 holes/lugs must be waaaay larger ring than 8x6.5??
__________________
  #39
Old 11-25-2014, 07:14 AM
Weareweird69
Look at the RING/PLATE below the Top Ring/Plate
Those two rings/Plates get bolted together.
The BOTTOM plate has the 8x6.5 bolt pattern in it, with some of the bolt holes covered up. The holes are large so you can run a lug nut onto the studs with a socket.
The holes that run along the outside of the rings/plates are just for securing both plates together as ONE adapter then.
  #40
Old 11-25-2014, 07:22 AM
Weareweird69
Here is my set, that is assembled.
These ones have studs in the back, that you can barely see.
  #41
Old 11-25-2014, 08:18 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Look at the RING/PLATE below the Top Ring/Plate.
Well dam, I had no idea thats what it was.
What a dumb way to do it.
__________________
  #42
Old 11-25-2014, 08:25 AM
Weareweird69
It's the only way since the number of studs is more and the bolt spacing is so close
  #43
Old 11-25-2014, 11:24 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
They should have just done 10 lug hubs and use the dually adapters like everything else. But then again, it's Ford so what do you expect...
__________________
  #44
Old 11-25-2014, 12:59 PM
Weareweird69
Well. Ford didn't engineer any of this.
  #45
Old 11-25-2014, 01:24 PM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
The F-Super Duty?
__________________
Quick Reply: F-sd 4x4 conversion
