What is this?!
What is this?!
I have an electrical connection hanging above my brake pedal in my 69 F 100 that I have no idea what it is for. I am having trouble with my turning indicators brake lights and instrument panel lights and I am wondering if this not being connected has anything to do with my problem. I am having trouble posting the pics I took of it but it is a cubic rectangle of black plastic about 1.25" X 2" X 2" with 4 flat copper circles on one side for connections.
Any help?
Thanks,
Byron
Any help?
Thanks,
Byron
on
Any help?
Thanks,
Byron
Any help?
Thanks,
Byron
orich
MUSTANGS ETC....818-787-7634
WESLEY OBS........606-787-5293
GREEN SALES........800-543-4959
PEROGIE ENT.........609-448-5593
Beginning 1967, brake (stop) lamp switch located on brake pedal, has a dash harness feed wire connected to it. 1967 switch is 1967 only.
Parts catalog pics:
Left - 1967/69: 4 way flasher switch located on the inside of the glove box. 1968/69's with factory installed integral A/C uses a different 4 way switch than without.
Right - 1970/72: 4 way flasher switch located on dash below instrument cluster.
Notice locations of T/S & 4 way flashers. Both have 2 prongs, but 4 way is a H/D unit, has a louder CLICK.
Parts catalog pics:
Yep. Sure is. You can either buy one of the glove box factory ones with my part number above like Bill's pic, or you can do what I did on my 68. Both switches Bill showed take the same wiring pigtail. I simply cut the connector off at my glove box, extended those wires over to under the cluster. reconnected the wiring connector, and mounted the switch out of my 1971 parts truck under the cluster. There-by filling an open position. My cargo lamp is connected to the dome lamp so I had no "cargo" switch under my cluster.
