Alternator wiring diagram - Ford Truck Enthusiasts Forums
Old 07-01-2003, 12:44 PM
robjef robjef is offline
robjef is starting off with a positive reputation.
I have 90 model F150 with a 300 6 cyl. I have had the bad luck to have experience the infamous alternator fire that I read so much about in these forums. At any rate, the fire destroyed the alternator harness. I have purchased the new alternator plugs, but I need a wiring diagram for the ford alternators with two plugs. Can anyone help? Thank you.
Old 07-01-2003, 02:26 PM
joners's Avatar
joners joners is offline
joners is starting off with a positive reputation.
I guess it's like the same one on Mustangs? The 2G?
Here's one for a Mustang.
Old 10-24-2010, 11:29 AM
kennyinnm kennyinnm is offline
kennyinnm is starting off with a positive reputation.
Help
I have a 1974 F-100. The wiring is shot, scabbed together from previous owner. I need to figure out how the charging and starting circuits are wired...any help would be very much appreciated.
Old 10-24-2010, 05:06 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
1974 was like this if you have a "gen" light in the dash.
2G alternator with different wiring harness? nilzlofgren 1987 - 1996 F150 & Larger F-Series Trucks 6 11-15-2015 06:24 PM
1980 F-250 Alternator Wiring Diagram Lady Sutton 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-03-2013 03:59 PM
'86 F250 diesel alternator wiring BigJake86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-09-2009 11:39 PM
ezwire Alternator hookup sdetweil 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-13-2008 10:10 PM
3g alternator patjr_45 1987 - 1996 F150 & Larger F-Series Trucks 8 08-04-2007 11:15 AM
Tags
2001, 2g, altanator, altenator, alternator, alternators, diagram, diagrams, fire, ford, mustang, schematics, truck, wire, wiring, wirings
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
