whats what (85 canadian truck with DSII) what wires go where
Old 10-17-2010, 12:34 PM
Joe_C's Avatar
Joe_C
Joe_C is offline
THe engine is no longer in the 85 it is getting installed into a 96
info
1985 Ford F150 XL, Canandian truck with Non Catalyst factory setup.
1996 Ford F150 XL
Both are Standard trans
now i have it all ready but the wiring im confused as a few colors change on me
The IGN control box has 6 wires
Red
White
Orange
Black
Purple
Green
They pug into the trucks harness as follows
Red into White W/ blue dash
White into Red W/blue stripe
Orange into Orange w/yellow dash
Black into Black W/green dash
Purple into Purple W/blue dash
Green into Green w/ dot (forget the dots colour)
i traced green and it go's to coil negative, and runs back inside the truck to the dash cluster and terminates to nothing so coil signal (non tack cluster is what it has)
now my issue is the red/white swap and where do i find the resistor part i havent seen one yet,
and the Coils positive is wired to Red W/green stripe and i tested that and its a non resisted ign switched wire to the battery?
so im a little lost on the resistor part
oh and with the 96's coil feed support the draw the older style coil has? if it will im going to try feeding it from the 96's coil hot wire
This 85 engine does run and works good (drove it into the shop) before i removed it
Thanks all
Old 10-17-2010, 03:17 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
info
1996 Ford F150 XL
Red
White
Orange
Black
Purple
Green
Thanks all
First off... I did not know a 96 truck harness would have the matching plugs for the DS2 module.
What engine size is the 85 engine?
The red/white color swap at the DS2 modules 2 wire power plug is normal. On the module side of the plug the red wire should have power in RUN/START and the white in just START.
I don't believe a 96 will have a resistor wire in the truck side of the harness.
I would deal with the resistor issue after it is running and you can take some coil voltage measurements at idle.
Did the 96 have a square coil?
Are you using a round coil now?
What P/N DS2 module are you using? after market or motorcraft?
The current draw (coil feed support) will depend on the total circuit resistance, this is mostly a non issue if you are using a round coil. If you have a ohm meter, compare reading across the small terminals of the two coils.
After it is running we can sort out the need for a resistor and/or other options.
Jim
Old 10-17-2010, 05:29 PM
Joe_C's Avatar
Joe_C
Joe_C is offline
Jim
IT doesn't have matching plugs i am building a patch harness to do it so all stock connectors are there and all parts are using stock connectors
Both are 300" I6's
Where would the resistor be in the 85's harness?
Module is a after marker im thinking as its not branded ford or motorcraft anywhere on it just says "Heavy Duty"
Yes 96 uses a Square coil
Yes i am using a round one for the 85 motor
Anything else? (sorry just ina hurry right now way to much going on and not having my truck sucks lol)
Thanks for the help
Old 10-17-2010, 06:10 PM
JimsRebel's Avatar
JimsRebel
Both are 300" I6's
Thanks for the help
The resistor wire is burried in the truck harness from the IGN switch to near the 4 wire connector, near where the DS2 module mounts. It is not something you can move to the 96.
There are other options, like using a ballast resistor.
Will post a picture of the resistor wires location shortly.
Old 10-17-2010, 06:27 PM
JimsRebel's Avatar
JimsRebel
The resistor wire is the rubbery feeling pink one (smaller center wire in pic) in the 3 in 1 out splice just above the wire cutters show in the photo.
The brown wire is the start bypass wire. The large red one is a "resistor bypass" wire.
The photo is from my 1986 with a 300. The 85 should be the same.
Does the 85 have a starter solenoid with 2 large and 2 small terminals?
Are you going to use the newer style starter or the one on the 85?
Old 10-17-2010, 07:01 PM
JimsRebel's Avatar
JimsRebel
more info here
https://www.ford-trucks.com/forums/6...-switches.html
Franklin2 can post a wiring diagram, I could find one
Old 10-17-2010, 07:08 PM
JimsRebel's Avatar
JimsRebel
Old 10-17-2010, 07:30 PM
Joe_C's Avatar
Joe_C
Joe_C is offline
Thanks for the picture and links
85's solenoid is a 3 post unit, the 96's is a 4 post using only 3 posts
Newer style starter as I' using the M5R2 trans and the 85 uses the older style starter and the 96's was about 3 weeks old
Old 10-17-2010, 07:50 PM
Joe_C's Avatar
Joe_C
Joe_C is offline
Some pictures i took with my crackberry
Prior to removal
Ign Control box
and its wires
In the 96 still needing hooking up
Will take better shots with my Digital cam when its done
Old 10-20-2010, 12:59 AM
Joe_C's Avatar
Joe_C
Joe_C is offline
MY coil is [Here
what resistance do i need to use to make this work out guys?
Old 10-20-2010, 07:19 AM
JimsRebel's Avatar
JimsRebel
The ballast resistor should be close the the coil primary resistance.
So look for a ballast resistor around 1.2 ohm or 1.0 ohm
Old 10-20-2010, 09:06 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Autozone has a Mallory resistor part number 700. They also have a part number CR105 for a Chrysler, but they don't list the ohm value. It would be simple enough to take you meter to the store and check it, especially since it's so much cheaper. You might want to search for other Chrysler vehicles and see if they have different resistors in stock.
Old 10-20-2010, 10:13 AM
Joe_C's Avatar
Joe_C
Joe_C is offline
Only one the local part store had was a 4.8 ohm dual unit so I could wire it to 2.4 ohm but its still higher then the 1.4 ohm of my coil
How close is good enough ?
Old 10-20-2010, 01:20 PM
JimsRebel's Avatar
JimsRebel
2.4 ohm is too high; basically the ballast resistor would drop 2/3 of the applied voltage leaving 1/3 left for the coil. The ballast resistor works as a voltage divider. I would like to see 6-8 volts at the coil positive but would be OK with 10 volts at idle on the coil positive.
Higher voltage at the coil positive (lower ohm ballast resistor) means higher current flow and thus the coil and the DS2 module can get to hot and fail.
2.4 + 1.4 = 3.8
2.4 divided 3.8 = .63
.63 x 14 volts = 8.84 volt drop across the ballast resistor and 5.15 volts at the coil positive
Voltage Divider Calculator
input voltage = 14 (or what your ALT produces at idle)
R1 = ballast resistor
R2 = coil primary resistance
Output voltage = coil + voltage
Old 10-20-2010, 01:39 PM
JimsRebel's Avatar
JimsRebel
Most ballast resistors have a high side and a low side. I haven’t seen a dual ballast resistor with equal resistances. The higher resistance side is usually around 5 ohm and the low side can vary from .5 ohm to 1.2 ohm.
If you use both 5 ohm and 1.2 ohm in parallel you would get .96774 ohms.
You should be able to find something that will work at a local auto part store.
Info here
Replacing electronic ignition completely in 1970s-1980s Chrysler, Dodge, and Plymouth cars and trucks
Quick Reply: whats what (85 canadian truck with DSII) what wires go where
