Upgraded headlights
on
Upgraded headlights
I put a brightsource hid kit in my wifes jk wrangler. It was a great upgrade to this rigs crappy lights. I figured I would put the same kit into my 2012 superduty. Great upgrade in lightin up the road but I started getting highbeamed. So, I lowered them down a bit. Still getting high beamed so I lowered them so they are pointin at the road right in front of the truck. Still getting highbeamed! In my wifes rig they are not too bright to oncoming traffic. Its lifted runnin on big rubber. I don't know what to do now about my superduty. I hate to take them out but I cant be pissin off oncoming traffic either. The beams seem well pointed but it does disperse a lot of light 'all over". What upgraded light are you guys usin? I see plenty of "blue tinged" lights on other superdutys that don't blind me.
If I had to hazard a guess the reason your wife's jeep doesn't get flashed is because the natural cutoff is better and its lower to the ground.
I had 05-07 headlights retrofitted and now I have no issues driving at night. 20 feet on either side of the road, more light down road then I can use with the high beams on. And I have a perfect cutoff line so I don't blind oncoming traffic
HIDs in the stock halogen housing is illegal and will blind oncoming drivers 9/10 times. In order to make halogen housing not blind oncoming drivers with HIDs you have to align the HID bulb so that it matches PERFECTLY to where the halogen bulb did and even then it may blind oncoming traffic. If you want HIDs retrofit projectors. You can get the diy kits from theretrofitsource.com or you can have the work done by companies like black flame customs, lightwerkz, or buy complete drop in housings from blackbird customs.
on
Thanks guys. I am up in bc ,Canada. I went to all my local shops and didn't get much help. I figured a new housing would fix me up but the shops offered little help other than selling me new housings with a new hid kit, to match these housings. I will look into some of the shops you guys mentioned. I see led replacement bulbs are being offered by sylania now. I wonder if these will give a reasonable upgrade without the cost of buying new housings which run about $800 up here.
sounds like your lights are aimed to high. i have projectors which are twice as bright as silver stars and have yet to get flicked.
freerider
Aftermarket Products
10-24-2014 12:51 PM
