Ford F5
Old 03-09-2014, 11:12 PM
fordf5's Avatar
fordf5
fordf5 is offline
Yea the valve assemblies are new and waiting.
I had 3 head bolts that were stuck and ultimately broke and guess what, they all have the water jacket crack. I had read multiple times not to worry bout them and use some ceramic thread sealant. Gonna be looking for some 080 pistons and rings and will proceed after that. Just gonna have to slow down...Remember,,, I was told that it ran good just needed brakes.
.Can anyone shed some light on the meaning of these casting numbers/codes???
.Thanks ....Roger
  #47
Old 03-09-2014, 11:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Can't help with those numbers; since the original numbers were stamped over, I'd guess the second ones are a rebuilders mark. From the date codes on your bearings (2 65 = Feb 1965) and the existing overbore, no question the engine has been rebuilt at least once. What is pertinent for buying parts is that your engine is actually an "0BA" (zero BA), which means you should have drilled oiler holes on the connecting rods, if they are all original to the engine. You may also have rotator-style valves, can you post a picture? If you look on the back of the block, right under that K-number, to the right of the oil pump drive cover plate, what is cast into the block? Should be 0BA or 1BA.
You can get new pistons up to 1/8" oversize, but I'd go the minimum.
  #48
Old 03-10-2014, 12:03 AM
fordf5's Avatar
fordf5
fordf5 is offline
I will check for the OBA or 1BA tomorrow.
Valve assemblies were kinda a hodge-podge some rotators some not, I never knew what was coming out.
Rods were kinda screwy tooo. No. 5 rod had a 5 that was overmarked with a 6, and #6 had a # 5 marked on the rod,,,go figure.
  #49
Old 03-10-2014, 07:55 AM
fordf5's Avatar
fordf5
fordf5 is offline
To the right of the oil pump cover and under the K# is a X and lower down is a 2C in the casting, but nothing else,,,,great, more puzzles...
  #50
Old 03-10-2014, 08:05 AM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,610 Likes on 1,454 Posts
Nice script bed!
  #51
Old 03-10-2014, 02:27 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
Roger, maybe this will help you find the numbers that Ross mentioned
  #52
Old 03-10-2014, 05:25 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
The important considerations for an 8BA block are the valve seats. During production from 1949 through 1953 Ford eliminated the hard seats. Hard seats on the intakes aren't really necessary, but are nice if you have them. You do need hard seats on the exhaust.
If you want to learn more than you need to know about different flathead blocks, there is a thread on the Ford Barn with a lot of details: Engine block I.D. pictures - The Ford Barn
  #53
Old 03-10-2014, 07:23 PM
fordf5's Avatar
fordf5
fordf5 is offline
Yep that's where I looked.
Got some pictures
.Any ideas???
Thanks Roger
  #54
Old 03-10-2014, 09:23 PM
harleymsn's Avatar
harleymsn
I've got another block in the back of my truck, I'll pull it out tomorrow and check to see if that one is different. BTW, from my measurements, the stamping should be under the black mounting plate, below the stampings that you are seeing. The 2C on yours is about the same place as the 5 on mine.
  #55
Old 03-10-2014, 09:55 PM
fordf5's Avatar
fordf5
fordf5 is offline
Not what I want,,, but I have made a decision!!!!!
Gonna do as some have suggested and hone the cylinders as best as I can.
The bearings that were in it plastiguage to within specs.
Already have the new valve assemblies.
Ordered some parts
New rings
Complete gasket set with copper head gaskets
New stud kit
Ceramic sealant
Ultra high temp silver paint (for the head gaskets)
Gonna put her all back together and see what I got.
The $$$$$ for the speed shop,new bearings and yadda, yadda, yadda are too over the top for me right now.
This will give me time to accumulate what I need and do it all over again ifn I need to.
Who knows maybe the county will hire me to do mosquito patrol....
...Roger
  #56
Old 03-11-2014, 08:38 AM
fordf5's Avatar
fordf5
fordf5 is offline
Found It!!!!!
8BA inside valve galley beside of the hole where the fuel pump push rod is.
sure enough, it says 8BA,,,,
  #57
Old 03-12-2014, 08:40 AM
fordf5's Avatar
fordf5
fordf5 is offline
New valves are all lapped and ready to go,,,just waiting on the big brown truck!!!
.....Roger
  #58
Old 03-13-2014, 07:10 PM
fordf5's Avatar
fordf5
fordf5 is offline
Big brown truck delayed cause of snow,,,,maybe tomorrow...
  #59
Old 03-13-2014, 07:20 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
We're all tingling with antici-
  #60
Old 03-13-2014, 07:21 PM
The Horvaths
..pation!
Keep us posted.
Quick Reply: Ford F5
