Will 16.5 x 12.50s fit 16.5 x 9.75 wheels?
Old 03-03-2014, 08:13 PM
Buyerz's Avatar
Buyerz
Buyerz is offline
I have a set of 16.5 x 9.50 Aluminum hurricane wheels. I'm looking at new BFG 33' All terrain 16.5 x 12.50 tires. Thats the only size I can find. Will they fit?
Old 03-03-2014, 08:17 PM
Dave145's Avatar
Dave145
Dave145 is offline
those tires are 3" wider than the rim...IF you got them mounted on the rim, they would look awkward because the tread would be that much wider than the rim. So I would say no.
Old 03-03-2014, 08:27 PM
lasthighboy's Avatar
lasthighboy
lasthighboy is offline
yes they will fit. 3 inches isn't bad. the tires should probably have an advertised recommended wheel size on them as well.
Old 03-03-2014, 08:28 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
I've seen many trucks from the 80's, 90's and Super Duty's run 35x12.5 or 315's on a factory 8" or 8.5" whatever they are wheel. I always thought they look fine however I run a 17/40-16.5 on a 9.75" wheel so maybe my opinion is biased. My tire is 14" from edge of tread to tread.
Old 03-03-2014, 08:48 PM
earthquake68's Avatar
earthquake68
earthquake68 is offline
Yes, they'll look just fine. These are 16.5 X10. I can't believe 1/4" would make them look any different than these.
Old 03-03-2014, 08:57 PM
Buyerz's Avatar
Buyerz
Buyerz is offline
Thanks alot! Does anyone know where to get the special/a good alternative style lug nuts for Western style hurricane wheels?
Old 03-03-2014, 09:00 PM
Dave145's Avatar
Dave145
Dave145 is offline
huh. okay good info then. I was under the impression they wouldnt fit. Good stuff.
Old 03-03-2014, 09:04 PM
earthquake68
Usually you can get whatever you want from the parts store. You'll have to buy two sets, but that's the cheapest way to go. I needed the shoulder nuts for my wheels. They have 1/2" / 20 nuts in sets of 20. 16 regular nuts and washers and 4 locks. Well, 16 times 2 is 32. you just end up with 8 locks extra. It's still cheaper than buying 32 lug nuts individually.
Old 03-03-2014, 09:06 PM
earthquake68
Rule of thumb is, you can use a wheel 2 1/2" narrower than your tread width. Usually the advertised tread width is actually the section width. The tread width is a bit narrower, so you can get away with narrower wheels.
Old 03-03-2014, 09:30 PM
good to doo's Avatar
good to doo
good to doo is offline
ya I remember when I had my first beer
Old 03-03-2014, 09:40 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
Old 03-04-2014, 09:13 AM
704 dentside man's Avatar
704 dentside man
704 dentside man is offline
I've run 12.5" wide tires on 8" wide wheels, 13" and 14.5" wide tires on 9.75" wide wheels and 15" wide tires on 10" wheels. You'll be perfectly fine.
Old 03-04-2014, 10:10 AM
EricJ's Avatar
EricJ
EricJ is offline
the width of the tire is at the widest point of the sidewall, not the tread, and 3" , isn't that bad. I'd do it if they were mine.
Old 03-04-2014, 03:14 PM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
slots
old school slots ansen 16.5 x 9.75,,,and oh yea 12.50 tires
Old 03-04-2014, 03:25 PM
petrovich79f250's Avatar
petrovich79f250
petrovich79f250 is offline
Ive got the 33x12.5x16.5 bfgoodrich all terrain tires on 16.5x11 hurricane wheels ... They look so good
[IMG][/IMG]
1973F100Kid
04-27-2013 09:30 AM
jaspirr
23
12-31-2009 04:49 PM
Saz221
1999 to 2016 Super Duty
12-21-2009 02:32 PM
Dragrazor
07-14-2004 01:43 AM
ccarrara
1997 - 2003 F150
12-02-2003 11:40 AM
Quick Reply: Will 16.5 x 12.50s fit 16.5 x 9.75 wheels?
