1996 F-250 7.3 Diesel crank but no start - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-03-2014, 08:00 PM
Moeford1996 Moeford1996 is offline
Moeford1996 is starting off with a positive reputation.
Have replaced valve cover gaskets, glow plugs, ICP, High pressure control pump, IPR valve, ECM,ICM, Fuel bowl heater and switch and IDM. Still having problems getting to start and then stalls when apply gas. Any suggestions? I also do not have access to any testing equipment.
Old 03-03-2014, 08:12 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Welcome to FTE! Have you checked your fuel pressure? There is a valve on the side of the fuel pressure regulator (FPR) that you can use a stick style tire gauge to check the fuel pressure.
Old 03-03-2014, 08:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Talking
Quote:
Maaybe because you are using "GAS". JK.
X2 welcome. You just arrived to the best forum ever. . Made what Bill suggested above. BTW do you have WTS ligth?
Old 03-03-2014, 10:20 PM
Will try to check fuel pressure. Also what is WTS ligh? Sorry still trying to understand abbreviations and not sure where all the parts are. Is there a good place to look up where parts are on the motor?
Old 03-03-2014, 10:34 PM
WTS light is working. What should fuel pressure be?
Old 03-03-2014, 10:37 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Have you replaced the 'crankcase position sensor'?
Old 03-04-2014, 06:44 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
^^ what he said^^ Ford or IH only.
How many miles on the truck? How old is the oil and is it full? Have you checked/changed the fuel filter? Is/was it black? Notice anything in the fuel bowl? Any injector work ever done?
As I'm sure you know, that's a lot of parts to be throwing at it to try to fix it. This situation shows that testing equipment will pay for itself. Not trying to bash on you, just saying.
Old 03-04-2014, 07:41 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Wink
minimum 20 psi cranking and 50-70 idle.
Check this link:
http://www.ford-trucks.com/forums/12...ont-start.html
Old 03-04-2014, 07:43 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Wink
This is for you
http://www.ford-trucks.com/forums/10...finitions.html
Old 03-04-2014, 07:45 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Wink
Old 03-07-2014, 06:01 PM
Quote:
Yes I have.
Old 03-07-2014, 06:03 PM
Thanks for all the suggestions, will be trying to check more again Saturday.
Old 03-07-2014, 06:04 PM
Yes I have.
Ford or IH? Part store ones are junk.
Old 03-14-2014, 11:13 PM
ProjectDually's Avatar
ProjectDually ProjectDually is offline
ProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to behold
The IHC/Blue CPS
The part oldbird is referring to is: IHC#1876736C91
In case you were wondering, or didn't know.
It's "the blue CPS" everyone talks about.
This CPS offers an advanced timing, and is reputed to make your truck run quieter, smoother, and increase fuel economy with more accurate injection of fuel.
Price is slightly more than your average parts store. Runs 40$ shipped from Improved Blue CPS for 7.3L Ford Powerstroke Diesel
1996 f250 7.5 liter Kfx700 1987 - 1996 F150 & Larger F-Series Trucks 7 02-28-2014 01:18 PM
P0300 1996 F150 4.9??? 88PONY 1987 - 1996 F150 & Larger F-Series Trucks 2 11-27-2013 10:56 PM
P0401 & P0411 error code on 1996 4.9L HarleyFXDL 1987 - 1996 F150 & Larger F-Series Trucks 9 10-13-2012 09:33 PM
Motorhome on F53 Chassis gt5-33 Large Truck 4 10-09-2012 08:20 PM
460 valve adjustment question riverratba Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 11-10-2011 04:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
