Somewhere around 2002-2003 ford changed the thread pitch of the factory lug nuts. I'm needing a set for my 2002 EX, can anyone confirm the size and pitch?
Awesome does anyone know the size so I can buy a set. I have aftermarket acorn lug nuts and need a set if factory lug nuts for a factory set of rims I want to use.
The E series still used the 14x1.5 until the end. The F series switched to the 14x2 in 99-04 trucks/excursion. Some E99 models had the 14x1.5 but that does not apply to the excursion. Any lugnuts from a 99-04 SD will work including the 05 excursion only.
I was able to find a full set at a junkyard, all 32 cost me 5.00!
Interesting, but doesn't mesh with my experiences. I replaced my factory axle housings on my '05 EX with housings from an '01 EX (with 4.88 gears, the reason for the swap). The '05 had the fine thread nuts and the '01 has the coarse thread, I had to buy 16 of the coarse ones to finish up the swap. I bought mine from Tousley Ford and paid more, I just didn't remember the details on the size and thread count or I would have posted the answer earlier.
my 03 Ex has different thread pitch than my 02 F350SD can’t remember which is which but they are definitely different I believe the truck to be coarse and the EX is fine
Thanks!
Depending on when your 02 Ex was manufactured will determine if you have course or fine threat lugs. I would recommend taking a lug nut off your Ex that you know fits properly and head to your local Auto Zone or whatever auto store that is in your neighborhood and test them out. Most stores have sample studs near the packaged lugs in order to determine the proper size. Remember that Factory rims require flat seat lugs.
Edited for correctness, thank you Tom I was thinking about one of my other vehicles when replying.
Depending on when your 02 Ex was manufactured will determine if you have course or fine threat lugs. I would recommend taking a lug nut off your Ex that you know fits properly and head to your local Auto Zone or whatever auto store that is in your neighborhood and test them out. Most stores have sample studs near the packaged lugs in order to determine the proper size. Remember that most Factory rims require cone seat lugs unless you are moving up to the 18” 04’s or newer which require flat seats.
Just a slight correction Vinny, all factory EX wheels came with the flat washer faced lug nuts, no conical seat nuts on OEM factory wheels that are hub centric.
When I did front brakes and bearings on my 2002 RWD, I had to get new lug nuts because the new hub was different. Now have 2 different lugs for front or back.
That’s because the new front wheel bearings were fine thread and the original rear lugs are course.
Very common because many parts counter personnel don’t realize that the thread count changed in model year 02 during production.
