Fuel tank problems - Ford Truck Enthusiasts Forums
Fuel tank problems
Old 03-03-2014, 03:24 PM
Hughesjr84's Avatar
Hughesjr84 Hughesjr84 is offline
Hughesjr84 is starting off with a positive reputation.
Fuel tank problems
Hen I try to use my front tank it acts like its sucking air. The rear tank works fine any ideas ?
Old 03-03-2014, 03:57 PM
fordtruckman838 fordtruckman838 is offline
fordtruckman838 is starting off with a positive reputation.
Sounds like you may have a crack/ hole in the line or the pickup tube in the tank may have broken off. Does this happen continuously or is it just below 1/4 tank or so? It could be an o-ring where the line clips onto the tank or on the back of the selector valve also.
Old 03-03-2014, 08:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
you'll have to drop the tank or lift the bed to find out.might want to just hold out a couple more weeks or April.....warm weathers' coming!
Old 03-04-2014, 07:20 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Could also be the line from the selector valve to the tank, but it's probably in the tank. The line on my sending unit broke when I was replacing the tank. I was able to heat the old one where it goes into the tank to melt the solder, then solder in a piece of 3/8 steel line to replace it. Ran the steel line to the bottom of the tank to eliminate the shower head/ cone of failure.
Old 03-04-2014, 03:48 PM
Hughesjr84's Avatar
The front tank is full and it won't pick up anything I'm going to wait till it warms up the rear tank is working fine
Old 07-08-2014, 07:16 AM
midapo midapo is offline
midapo is starting off with a positive reputation.
Quote:
Did you fix your fuel tank problem? My '94 has started doing the exact same thing.
Relocating Fuel Tank timpage 1961 - 1966 F-100 & Larger F-Series Trucks 27 08-10-2016 11:53 PM
help with a fuel tank. flyinbrian04 1967 - 1972 F-100 & Larger F-Series Trucks 13 02-27-2016 06:04 PM
Higher Capacity Gas Tank volwing1 6.2L V8 2 08-14-2015 07:54 AM
mid fifty 19 gallon tank ETOWN55 1957 - 1960 F100 & Larger F-Series Trucks 2 12-26-2014 08:15 PM
Fuel tanks creedua 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-22-2014 03:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
