bearing specs - Ford Truck Enthusiasts Forums
bearing specs
Old 03-03-2014, 11:43 AM
demon87 demon87 is offline
demon87 is starting off with a positive reputation.
bearing specs
Okay so my friend bought a 08 ranger 2wd 3.0l nee off ghe showroom floor. She spun 2 main bearings. I bought a new crankshaft that came with bearings. The engine was a reman 07 when i pulled. So said ths sticker on it. Yea not happy with that. The crank i pulled out was stamped 06... more fun. Anyway i put everything back in to spec givin in haynes. Needless to say it wont turn over. Main bearings on too tight. I need the specs for the clearances and tq. Any help would be greatly apperciated!!! Oh btw i only have two days to finish and get it back to her...
Crankshaft won't turn, on ford 300 i6. j-swizzle Performance & General Engine Building 5 02-25-2016 10:59 AM
2003 Ranger 2.3 dohc crankshaft main bearing torque spec? srmauer Ranger & B-Series 3 12-27-2015 11:46 AM
Crank Binding on Install jbancroft 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-28-2014 02:57 PM
oversize rod and main bearings? jbancroft 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-30-2014 05:29 PM
Rear Axle Bearing Torque Spec jasonodsky Excursion - King of SUVs 4 10-09-2014 12:23 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
