The factory wiring is designed for 55W bulbs. By the way, those 100W bulbs are usually for "off road use only". If you intend to use them, a relay harness is typically required.
Typically if your not happy with a regular 55watt high performance light you're not going to be happy adding more watts, its usually the pattern or the alignment that is your issue.
