broke down 96
#63
#65
So I finally found a used Remanufactured PCM last night and put in the truck. It started and ran fine the little I drove it. I believe this has been a issue since before I got the truck. The throttles is crisper, truck is a little peppier and not acting up. Hopefully this will fix my issues and give me a little faith in using it as a donor instead of selling it.
#67
#69
#70
Dorman sells them either as individual parts or as a kit with the shackle and hanger both. I got mine from Rockauto but I believe most of the more widely known auto parts stores have them as well. They're pretty inexpensive too...
More Information for DORMAN 722005
$26 a side.
More Information for DORMAN 722101
$42 a side
Advance auto carries the exact same parts, but their prices are close to double. If you go to Advance they use the same number but they put a dash in the middle (722-101, etc.).
If it were me, I would feel a lot better getting the new parts from Dorman than trying my chances finding a good one in a yard and getting it off the truck in good condition. Suit yourself though.
$26 a side.
$42 a side
#72
So I bought the Dorman 722101 and I'll tell the rest of you don't waste your money. The hanger lined up with three of the old holes. The hanger is way to wide at the spring side so I'll have to make a spacer to take up some space. When I get it done I'm going to clean it up a bit and put the truck on Craigslist.
#75
Now that you mention it the ones I installed were a bit wider than the spring was as well, but they cinched up just fine when I torqued the bolt down. I don't know if there is a better alternative than that without going to a custom made lift shackle from Sky manufacturing or someone like that. Mine did line up perfectly with the holes from where I removed the rivets though.
