Another CV Swap! MillerTme's 57 - 302 / 4R70w build
Having a few growing pains with my 57 not stopping and steering sloppier than a bowl of cereal I decided to for-go the Crown Vic swap and go over the front end. The 302 I'm running was mated to an AOD with a cracked bell housing. Initial thoughts were to buy a good/used AOD and ended up with a much better 4R70w. Here's my goal:
1. Crown Vic front End
2. 79 Econoline Tilt/Auto Steering Column
3. Relocate 7" Master Cyl + Booster
4. 03 Mustang 4R70w Auto + Baumann TCS
5. New Cab Mounts (yea they're shot!)
Pictures of the truck:
Engine out! Old 302 K Member that was half *** welded in by the previous owner:
I'm copying Rippy154's CV swap design and went with 3/16" 6" angle iron seam welded to square the frame. My Mig regulator is shot (new one on the way) so am getting a bit more splatter than I'd like. Weld penetration is good though which is all that matters
Frame drilled out for the CV pegs and through bolts. Welded and fits great!
Swaybar bushing brackets nuts welded inside frame.
Inner frame prepped and painted and ready for box. I'm boxing the frame in segments for easier fitment.
It rained today so haven't made much progress. Yea I'm doing this build in my driveway More pics to come!
Thanks. This has been one hell of a project spending about 30 hours week to get this runner back on the road.
The CV swap I used was off an 05 Merc Marquee.
Here are some updated photos of where I'm at.
New in-tank fuel pump added. The frame rail pump wasn't recommended for an EFI setup.
Plates welded seam welded in 4 chunks to box the front back to the cab mounts.
Painted and pretty. CV front is sitting on the frame, not bolted at this point
Control Arm bracket made and welded to both sides of the frame. Welded nuts to allow for an easy install.
Cab corners cut, and sheet metal bent and seamed. Also used a urethane sealer to ensure this area is now water tight.
Not the best shot but floor pans, cab mounts, and hump finished.
Firewall stripped, holes all patched.
Battery box finished and ready for paint
Steering column bracket fab'd up. Using a 79 Econoline tilt column. I've had to cut down 5" to fit and clear.
Skipping quite a bit now but the motor and trans are installed. Had a high pressure line fab'd up for the stock Explorer 302 pump. Works great!
Next are brake lines
Talking to the Mustang guys, the late model Explorer 302's were the lowest milage, easy to find and had the best bang for the buck. Motor cost me Just under 400 complete with a tunable MAF ECU. I prefer EFI over Carb as I plan to daily drive my truck and am looking for a simple turn-key truck.
Took it out for a spin last week and wow, that trans controller is aggressive out of the box! 3-2 and 2-1 downshifts are beyond impressive!
The speedo needed to be corrected, I wasn't doing 55 in residential area :P
Sure! What kind of pics are you looking for?
I'm currently working on the rear end. Decided I wasn't smart driving around with a 4disc combo valve and still having drums in the rear.
I used an Explorer 8.8 Trak Loc 3:70 rear end. Ended up having to replace the spider gears, clutch plates, and S spring which should now give me a reliable and fun. rear end for years to come.
Bed had 1 old wood spacer. Not sure who's good idea it was but shocked it was still in 1 piece (also why the bed set weird on one corner...
Bed removed, old and ugly!
Frame was C notched using CPP's kit. Only have pictures after the frame was stripped and painted (same as the front end)
Axle tubes, shock mount, and spring mount welded to the axle. Painted with a hammered grey. Looks great!
Shock tower now welded in and painted. Shocks fit great! Swaybar end links fab'd up and installed. Axle cut, balanced and new u-joints installed. Next is re-fitting the gas tank and making new hard lines.
Damage truck
33
11-18-2017 06:54 PM
mtnjason
72
10-12-2016 09:15 AM
