trying to figure out my fuel fill issues - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Log In
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 03-02-2014, 03:33 PM
nojoke327's Avatar
nojoke327 nojoke327 is online now
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
I've read all the threads about the evap can being clogged or a line being pinched but I still have a few questions. I dropped the evap can today and checked it and it wasn't clogged. I even hooked a air hose up to it and air flowed through it fine. I even hooked a air hose up to both lines feeding the canister. The lower hose flowed air just fine but the top hose wouldn't flow any air. I followed the line as best I could and didn't see any crushed or pinched spots.
Does anyone have any ideas that could help because I am lost on what to do
__________________
2000 Excursion xlt 6.8 aka "my big fat ex"
2008 reg cab F350-----sold
US Navy Seabee 07-13. BU2. NMCB 27/22
OEF 09-10 Afghanistan.
Old 03-02-2014, 04:19 PM
scraprat's Avatar
scraprat scraprat is online now
scraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud of
year of truck, engine?
Old 03-02-2014, 04:32 PM
nojoke327's Avatar
Truck in my Sig
__________________
Old 03-03-2014, 08:25 AM
nojoke327's Avatar
Anyone?
I also tried blowing air into the 2 lines coming from the tank to the canister. One.line took air and the othe wouldn't take any
__________________
Old 03-03-2014, 11:31 AM
Sebs Sebs is offline
Sebs is starting off with a positive reputation.
I recently had this issue with my 2008 V10. It happened after the computer had been reset and before the emissions monitor was complete. Once the monitor reset everything was fine. Has your battery been disconnected recently?
Old 03-03-2014, 01:02 PM
Wolfboro's Avatar
Wolfboro Wolfboro is online now
Wolfboro is gaining momentum as a positive member of FTE.
I have been hearing this issue on and off during last 5 years, at least . Nobody in this forum came back with a definitive fix that I can recall .
Keep us informed
__________________
Beware of hip-shooters and faked experts.
2003 F-350 SD, XL SuperCab, SRW, 2x4, LB , V10, 4.3 rear axle w/LS , 6-spd manual -ZF Friedrichshafen AG, no mod.
Old 03-03-2014, 05:07 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
I have a fix REMOVE IT
Sent from my iPhone using IB AutoGroup
__________________
2004 F-350, XLT, SC, SB, FX4, 5.4, 4R100 w/ .472 line mod valve & TransGo HD2 reprogramming kit, 4.30 gears w/ Detroit locker, zoo dad mod w/ STOCK intake, Gibson stainless headers, SPD y-pipe, 51509 cat, Borla 3" exhaust, 1" rear AAL, dually upper and lower overload spring, 08 diff cover, ProComp 22210 springs, more.....
Old 03-03-2014, 06:02 PM
nojoke327's Avatar
The carbon filter is not my problem.
Also the battery has not been disconnected lately
__________________
Old 03-03-2014, 06:48 PM
King-bRanch's Avatar
King-bRanch King-bRanch is offline
King-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant future
Ok I just spent some time trying to find what the hell i read the other day but no luck
I have a Diesel so I didn't mark the Thread but iam sure it was a Ford TSB on this very issue (slow filling at the pump).
I skimmed through it & as I recall the solution was modifying/relocating your Vent Tube Hose.
Sorry I cant remember but hope this points u in the direction
__________________
Warren....Check out my GARAGE with detailed Info & Pic's
Click Here >> http://www.ford-trucks.com/g/album/925729
Old 03-03-2014, 09:35 PM
nojoke327's Avatar
The vent tube is clear. And the charcoal filter it clear. One of the lines running from the tank to the filter is clear but the other won't let any air through it. I can't see and spot that it is kinked. There is a white and yellow lone at the filter. The white line is the one that won't let air through it. There is also a white lone that runs to a sensor in the engine bay and that one won't take air either. Now I don't know if there is a check valve on that line or not but something definitely seems to be preventing air passage which I'm assuming is preventing proper fuel filling
__________________
Old 03-07-2014, 12:18 AM
nojoke327's Avatar
Update on the fuel fill issue. After tracing all the lines in the truck I decided to try something when I got gas today. I unclipped the bottom line running into this sensor in the engine bay. The truck filled up like normal and I could hear the air pouring out of the line. I wonder if what ever this valve/sensor this is, has gone bad? Any ideas on what this is?
Click the image to open in full size.
__________________
Old 03-07-2014, 06:11 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
09-20-12*** SLOW FUEL FILL - 5.4 AND 6.8 ENGINES
TSB
09-20-12
Publication Date: October 5, 2009
FORD:
2005-2010 F-250, F-350
This article supersedes TSB 9-8-12 to update the vehicle model years, Issue Statement, Part List and Service Procedure.
ISSUE:
Some 2005-2010 F- Super Duty 250/350 vehicles equipped with a 5.4L 3V or 6.8L 3V engine may experience premature automatic shut off of the fuel fill nozzle. This may include box delete vehicles that have been upfitted with aftermarket utility bodies or vehicles that are operated in muddy or dusty environments, and may encounter a dirt clogged carbon canister system.
ACTION:
Use the following service procedure to resolve the concern if the carbon canister system is dirt clogged.
SERVICE PROCEDURE
NOTE: THIS PROCEDURE ONLY APPLIES TO F-250/350 PICKUPS AND F-250/350 PICKUP BOX DELETE VEHICLES WITH GAS ENGINES.
Inspect the vehicle's canister system.
If the canister system is not dirt clogged and the vehicle is a F-250/F-350 Pickup then proceed with normal diagnostics and do not continue with this procedure.
If the canister system is not dirt clogged and the vehicle is a box delete then replace the filler pipe (box delete vehicles only).
The new filler pipe should only be used for box delete vehicles that are exhibiting slow fill issues due to the aftermarket routing of the filler pipe with the upfitter's box (the new filler pipe kit provides additional design measures to improve the ability to fill the vehicle).
If the canister system is found to be dirt clogged, then continue with Step 2.
Replace the carbon canister assembly per Workshop (WSM), Section 303-13.
Relocate the fresh-air intake port to a more protected location using a new fresh air hose kit.
Replace fuel cap assembly.
Replace the fuel filler pipe (box delete vehicles only) that have been upfitted with aftermarket utility bodies).
NOTE: WARRANTY COVERAGE IS NOT APPLICABLE ON VEHICLES IF THE BOX DELETE FILLER PIPE HAS BEEN MODIFIED FROM THE INITIAL FILLER KIT TO MEET UNIQUE AFTERMARKET/BODY BUILDER INSTALLATION.
PART NUMBER PART NAME
9C3Z-9049-A Vent Kit
6C3Z-9D653-F Canister Pick-up (2005-2007)
9C3Z-9D653-C Canister Pick-up (2008-2010)
8C3Z-9030-A Fuel Cap Assembly
8C3Z-9B149-L Filler Pipe
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
092012A 2005-2010 F-Super Duty 250/350 5.4L/6.8L With Pickup Box: Inspect The Vehicle Canister System, Replace The Charcoal Canister, Install Fresh Air Inlet Kit, And The Fuel Cap Assembly 1.5 Hrs.
092012B 2005-2010 F-Super Duty 250/350 5.4L/6.8L With Pickup Box Delete: Inspect The Vehicle Canister System, Install Filler Pipe Kit 0.9 Hr.
092012C 2005-2010 F-Super Duty 250/350 5.4L/6.8L With Pickup Box Delete: Inspect The Vehicle Canister System, Replace The Charcoal Canister, Install Filler Pipe Kit 1.9 Hrs.
DEALER CODING
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Stuart
Retired Master Sergeant
FTE Guidelines
Old 03-07-2014, 07:26 AM
Double post FLIPPING iPhone
__________________
I believe that is the vapor vent sensor, it let's the gas tank vent the vapor into the motor so it burns off inside the motor so it doesn't vent into the air...... Pollution bull crap nothing more but a added headache
__________________
Old 03-12-2014, 02:24 PM
nojoke327's Avatar
I wanted to report back and say that the truck is filling up fine now. Maybe something was clogging the hose but after leaving it off to fill up that one time I have no issues now.
__________________
Similar Threads
IP lets tons of fuel exit to return system The_Josh_Bear Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 09-04-2015 04:17 PM
Fueling Issues GeorgePBurdell Ranger & B-Series 9 07-10-2015 12:28 PM
Codes 172, 175, 1405 Changed So Many Parts.... nivlage999 1997 - 2003 F150 10 09-28-2014 11:20 AM
E250 fuel filling problem Migdhorse 1968-2013 Full Size Vans 3 06-02-2014 05:57 AM
Fuel filler hoses? lance65 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-23-2013 11:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
