#1 cylinder burning lean? - Ford Truck Enthusiasts Forums
Old 03-02-2014, 10:13 AM
Clay frost Clay frost is offline
Clay frost is starting off with a positive reputation.
I have a 1994 f150 w/302, I pulled the heads to change head gaskets and the #1 cylinder on the bottom of the head is white, the only thing I can think of is its burning leen. The #3 head is really black and dirty. I don't know much at all about this stuff. Any help would be appreciated thanks
Old 03-02-2014, 11:48 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
It's possible you have a dirty injector so it would be a good idea to have them professionally cleaned or replace them with a reman set. The PCV valve dumps into the rear of the upper intake and as a result the rear cylinders often see more oil, a fix for this is to plug that hole in the upper intake, put a longer hose on the PCV and connect it to a spare port in the vacuum tree.
Old 03-02-2014, 02:45 PM
Dropped all the rods that go to the valve springs, now I have no idea which spring they go to. Is this bad or will it be ok
Old 03-02-2014, 04:13 PM
Conanski's Avatar
The pushrods you mean? If so it doesn't matter where they go but make sure they are clean and not plugged before putting them back in.. blow some compressed air through them.
Old 03-02-2014, 04:16 PM
Yes push rods excuse my ignorance I'm new to this. Since I have my valves exposed should I do anything with them?
Old 03-03-2014, 10:41 AM
Conanski's Avatar
If it ain't broke don't fix it.
Oil Burning 3.0 danvhp Ranger & B-Series 3 11-25-2015 11:20 AM
F350 460 issues boggerted 1987 - 1996 F150 & Larger F-Series Trucks 4 10-21-2015 08:50 PM
2.9L Head ?'s sledhead999 Ranger & B-Series 9 04-22-2015 07:02 PM
no low beam on my pass side head lite catzr440 1999 to 2016 Super Duty 4 06-17-2014 06:03 PM
Resurfacing cylinder head on a table saw GB SISSON 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-07-2014 07:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
