Vacuum Pump ?
you could check fuses. Fuse #27 (15 amp) is the one for pump and auxiliary heater control and brake shift interlock. Have you noticed other components not working too? It's best to resolve pump issue as brakes rely on pump for vacuum since engine doesn't produce it. Here's a pic of connector. Make sure ground is good and power key on run only.
You should be able to disconnect the vacuum lines from the vacuum reservoir, then with the vacuum pressure dissipated the pump should run (with key on). If not, then pump is probably bad, though I'd also check fuses.
If pump does run, then there's an abundance of info on leaks occurring at the 4x4 hub seals, or cracked vacuum lines at the front 4x4.
In my case, I have a leak at the heater/ac selector switch. Any leak of the vacuum, anywhere, will cause pump to run continually.
A no-run pump is probably a fuse, bad pump, or indicates that vacuum has been met and the pump has automatically shut off until more vacuum is needed.
Fuse 27 is good.
Pulled vacuum line to the res with key on and cycled 4x4 switch and HVAC controls. No pump sounds.
Then checked for power at the pump. It has power.
Looks like Im replacing the vacuum pump. Should I go with OEM or will Advanced Auto be sufficient?
Thanks for the help guys.
i had a issue up there with a new guy selling me wrong part and the guy that knows me tried to make mends and pulled up a screen for price match and rock auto was on the list just make sure to bring proof of price and make sure its exactly the same part numbers and supplier and you should have no issue , now i know he can do this i hit him with it all the time lol
