Power Steering Pump Brackets - Home Made
https://www.ford-trucks.com/forums/p...735512&thumb=1
Picture shows "rough draft" of brackets I made for my high mount fan engine and Saginaw Power Steering pump.
Since the picture I further shaped them with cutter and grinder then powder coated them. The pump is very solid with no flex in any direction and I only had to add a spacer for the engine side of the top bracket to make the pulley line up with the fan pulley.
They turned out very well and from a material standpoint I am $7.50 into them. Not quite as fancy as the store bought ones but the $125 + savings can be used for something more visible.
harrythehack
09-29-2018 06:06 PM
kd123
04-12-2006 04:55 PM
