Turbo a 360? - Ford Truck Enthusiasts Forums
Turbo a 360?
Old 03-01-2014, 10:51 PM
stang9090 stang9090 is offline
stang9090 is starting off with a positive reputation.
Turbo a 360?
Im starting a rebuild of an old 1972 FE 360. Im going to put in a hot cam and a few other mods. But the thought of a turbo to help out in higher rpms crossed my mind. Any thoughts, ideas, or advice? Thanks!
Old 03-01-2014, 11:35 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Throw the crank, rods and pistons in the junk pile. Upgrade to at least a 390 crank and rods, with pistons that make enough compression to work with your hot cam. You can go out to 445 with that engine.
Survival FE Engine Kits
Your pistons would actually get you 9 to 9.5 compression on the 390 crank and rod, but my bet is they are worn out, which is why I say toss 'em. Even if they are in spec, the ring lands have over 40 years of hammering, so why chance them in a new rebuild.
As for the turbo, you won't need it, and even though the 360 would seem to like a turbo, being that it is a low compression engine, the sunken piston and lack of quench would seem to me to invite detonation and make for trouble.
Old 03-02-2014, 04:17 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
I've tossed around the idea of running twin eaton m90 superchargers, if nothing else just because it would look cool.
but in all honesty it would really depend on what your plans are for the engine. and normally the higher rpms are not whats normally worried about.
Turbo rebuild kit KDAVID1 6.0L Power Stroke Diesel 15 02-05-2016 06:50 PM
360 Thrust Washer for Stock Housing? F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 4 07-22-2015 01:38 PM
370 info wanted Turbo Dog Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 11-12-2013 09:40 PM
Turbo rebuild- 360 thrust bearing? bkuuz1 1999 - 2003 7.3L Power Stroke Diesel 2 10-20-2013 11:06 AM
Ford 360 ver chry 360 FordFadgeole FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 12-09-2003 04:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
