Do it right the first time....
So periodically through out my build, especially here recently, I have had to go back and change/fix things that I tried to "save money on" before. I know I'm not the only one that finds themself in this situation every now and then but I know I have made things more difficult for myself later on in the build.
For instance, when I wanted to get my engine started in the frame for the first time. I went and bought an ebay $30 chinese electric fan, $35 on the electric fan wiring kit that went with the cheap fan, $30-40 on a cheap autoparts store control module for the duraspark II, used plastic fuel cell $80. I've had to go back and change all of that stuff therefore I've wasting my money on that cheap crap from before.
Something I'm going through now is: I bought a used 9" rear end a few years back and it had 5x5.5 bolt pattern. Keep in mind my MII IFS has a 5x4.5 pattern. Well my dad kept telling me to have the 9" axles drilled to to match the front..."Na I won't need to do that"...well a few years went by and I had bought some new wheels and tires. Everything is going great until I found out recently that I had a bent axle on that 9" I bought....Now I'm just sucking it up and fixing the axles the way they should have been done before and selling the NEW rear wheels I have now to get some with the right bolt pattern 5x4.5(can't return them as they have had tires mounted). If I would have had listened to my dad years ago I would have found out about the bent axle back then and wouldn't be in the pickle I am now with the wheels. So freaking frustrating but its all my fault. I just kept doing things the hard way (didn't know I was at the time, thought I was just doing it differently) but you live you learn.
All of these things (there's more I just can't think of them right now) I've "saved money on" has made my build take longer and costed me more in the long run.
Bottom line is: Do it right the first time guys! You will save time and money!
Sorry had to vent
Sorry had to vent
Not taken as a vent. Rather a well presented life lesson. We all tend to do what seems right at the time and many times that is a pocketbook issue. Lord knows I've done stuff that I've had to go back and change or modify. Truth be known, probably all of us have. Many times that older guy looking over your shoulder , parent, has been there, done that.
It helps to have a plan. And once you start the plan, don't change it! I had a gift of a complete Bronco 9 inch rear end from a friend. Because of my advanced age, I knew to take it apart and inspect it. As a result, the only thing I'm going to use in my 48 F1 is the differential case and gears. The rest will be sold to someone who can use this rear end which is too narrow for my F1. I will change the 28 spline differential for a 31 spline Detroit TruTrac, and in the process a complete rebuild and adjustment. Dollars spent, but the reassurance of fewer problems later.
Philip
Philip
I agree doing things on the cheap usually comes backs and bites you in the butt. As you get older, and hopefully better financially situated, you learn and start doing better.
One other thing to think about that I learned 10, even 20 years after the fact, is build the truck like it was already complete. Like most here I tore my F-2 down to the frame and started building it back up. As I went I installed the engine along with all of the tubing and hoses. Then came body parts and so on. As I was assembling these parts I stood over the frame and went to work. Well, 20 years later I needed to remove the radiator and realized I had installed the hose clamp on the bottom radiator hose clamp so the tightening screw wasn't easily accessible from the bottom of the truck. It was easy 20+ years ago because I didn't have any of the front sheet metal on the at the time. I've found a few other situations like this. It's kind of fun because I can actually remember the time I did these installations and who I was with at the time, my dad who is no longer with me and friends I have long lost contact with. Also, my youth.
There are times when I know I'm going to have to go back in and change/tweak/rebuild something. Sometimes the current situation dictates the shortcut. Soemtimes those shortcuts last a long time.
I fabbed up my gauge cluster on the cheap using junk yard parts ($20 total investment) as a temporary solution. So far its been 7 years or so....lol
Bobby
bites me in butt a few times a month... It's more of while you are there, you should do it... For example, I just got my truck ready for it madden voyage, I checked the u-joints before installing the DS. I determined the rear needed to be replaced and the front was good..
Oh boy, an 10.00 u-joint caused me to walk about two miles home when the front u joint blew up about two hours later on the way to the gas station. I have never had that happen, but man did it **** me off.
