Need A crank pulley - Ford Truck Enthusiasts Forums
Need A crank pulley
Old 03-01-2014, 12:14 AM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
Need A crank pulley
Short of a bidding war on ebay or buying a modern harmonic balancer does any one know of a source for a stock style 8BA or 8RT two groove wide belt crank shiv?
I kinda screwed up and ordered truck belts and pumps. Only to realize I have a car pulley. I would even trade if someone wants......
I do not mind used or new. Just don't want to spend $300 on a harmonic balancer.
Old 03-01-2014, 03:42 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by flipklos View Post
Short of a bidding war on ebay or buying a modern harmonic balancer does any one know of a source for a stock style 8BA or 8RT two groove (sheave) wide belt crank pulley?
8BA-6312-B .. Double Sheave Crank Pulley-3 11/16" long / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1948/53 Trucks / 1949 Ford Passenger Cars.
Old 03-01-2014, 11:58 PM
Well thanks for the quick reply ND. Now I know not to start calling obsolete dealers............
Glad to see you are still hard at it. Tried PMing you but see that you no longer take them. How can I get ahold of you if I need other ford parts?
Old 07-21-2014, 03:29 PM
jack orchard jack orchard is offline
jack orchard is starting off with a positive reputation.
Keep the wide belts
wide pulleys are hard to find because most new 8ba builds are using wide belts. that is because wide belt pumps are much easier to find and cheaper also. check the pictures in the mags. hope you found a pulley by now.,,...jack
Old 07-21-2014, 06:52 PM
Got one off ebay. Bled aout my ear to buy it though.
Old 07-21-2014, 07:37 PM
Happy
Glad you found one. You won't be sorry for going to wide belts...jack
429/460 Balancer-pulley alignment gremlins Rich Halsey 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-12-2013 11:50 AM
352FE Harmonic Balancer question Spyderjohn 1961 - 1966 F-100 & Larger F-Series Trucks 39 07-11-2012 01:18 AM
Harmonic Balancer Issue (Crank Pulley squeal) LTCPipkin Explorer, Sport Trac, Mountaineer & Aviator 1 04-24-2011 02:22 PM
352 ? harmonic balancer 410 Highboy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 02-12-2010 02:01 PM
64' 390 Harmonic Balancer vs. 76'. dburgess FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 05-11-2004 11:19 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
