Ford F250 V10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Ford F250 V10
Old 02-28-2014, 09:45 PM
AZ Gary AZ Gary is offline
AZ Gary is starting off with a positive reputation.
Ford F250 V10
I currently have a 2000 F250 with a V10 and pull a 10,000# fifth wheel RV. If I
went to a 2010 or newer 5.4 would I see a big differnce in power and performance pulling the same trailer? I really have liked the V10 but would like to get into a newer truck.
Old 02-28-2014, 10:29 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch Ravenwood Ranch is offline
Ravenwood Ranch has a good reputation on FTE.Ravenwood Ranch has a good reputation on FTE.
ive had a 01 v10 and a 05 5.4, i noticed an increase in fuel economy and a decrease in take off ability, the v10 and 5.4 are pretty much the same motor minus 2 extra cylinders. i pulled a 32 foot with mine and really didnt have much of a difference except on uphill pulls, hope that helps
Old 03-01-2014, 08:55 AM
Wolfboro's Avatar
Wolfboro Wolfboro is offline
Wolfboro is gaining momentum as a positive member of FTE.
Read the TOWING GUIDES
Old 03-01-2014, 09:10 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Irelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to behold
I pulled a 7000 TT with a 5.4. It did OK. I then bought a V10 - OMG!! The V10 truck didn't even know that trailer was there. Skip ahead a couple years and the TT was replaced by a 12,000#, 34 foot 5er. The V10 then did an OK but not great job with hills being what it didn't like - unless you like hearing 4-4500 rpm screaming to maintain some semblance of speed. As noted above, see the towing guides for the truck you are considering. It will, without looking, probably say that it will work but what it wont say how comfortably it will be to drive. But, with that said, if you only pull your 5er 2-3 times a year or to a seasonal CG, that 5.4 may be all you need - assuming that the tow guide will 'allow' that combo
Old 03-02-2014, 08:56 AM
bell4fan bell4fan is offline
bell4fan is starting off with a positive reputation.
If you are looking for a 2010 5.4, just find ya a V10. The 3v V10 had quite a bit more power than your V10, and substantially more than a 5.4. I believe the 3v V10s had 365hp and 465ft/lbs. A lot more power, and you might lose 2mpgs doing it.
Old 03-02-2014, 08:29 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Nothing wrong with the 05 up 5.4 AS LONG AS IT HAS 4.10 GEARS! Even if you get the V10 AGAIN find one with at least 4.10 gears if not 4.30 gears
Sent from my iPhone using IB AutoGroup
Old 03-02-2014, 09:29 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The 3V 5.4L has close to the same horsepower as your V -10, but you will be down on torque. The lower 1st gear of the transmission makes up for that quite a bit. You won't see any power gains with a 3V 5.4L, but in my opinion the truck will be more than equal to what you are driving now.
2008 3 valve v10 high miles? or 6.4 diesel? ajmicek Modular V10 (6.8l) 19 03-01-2013 06:57 PM
V10's any good? bigred1992 Modular V10 (6.8l) 36 06-04-2012 08:05 PM
V10: 2V vs. 3V WMNY 1999 to 2016 Super Duty 32 07-18-2011 03:19 PM
99 V10 head question shaggin1 Modular V10 (6.8l) 9 04-25-2007 08:25 AM
V10 heads jhemr Modular V10 (6.8l) 9 06-22-2004 05:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
