56 f100 5.0 coyote swap project (help please)
#121
Mike,
Parts should should keep from your donor vehicle:
PCM (Powertrain control module)
BCM (Body control module)
Fuel pump and sender assembly (gas tank too if you can use it)
FPDM (Fuel pump driver module)
EVAP canister contol solenoid (near gas tank on a Mustang)
FTP sensor (Fuel tank pressure sensor (by the fuel tank)
AC pressure transducer
Mass air sensor with inlet air temp sensor
Cooling fans
Throttle pedal assembly
Brake pedal position switch
Gear shifter assembly and cable
Instrument cluster
Steering column ( key sensor, ignition switch, speed control switch)
Cluster multi-function switch (controls display screen in cluster)
light dimmer switch (for cluster lighting)
Now, you may not elect to use all of these, but you can. The 3 wiring harnesses I noted above and be turned into a very basic Hot Rod harness, or to include any or all of the above items. If you live where emission systems are checked you should keep the evap emissions hardware and the catalyst.
By-the-way, always keep the UEGO sensors in the exhaust system, they are critical for proper engine function.
The motor mounts, trans mount & bracket, and the driveshaft are good things to keep as well. The less things you have to buy new the better.
Hope this helps.
Walt
Cooling fans
Instrument cluster
Hope this helps.
Walt
#123
Jerry,
Well, there are several options to find someone to do wiring in your area. Look for shops that do street rods or resto-mods, they will usually have a wiring guy they use who can custom make harnesses and/or strip out your factory harnesses.
You can ship your engine and trans harnesses to Chris at Hotwire Auto
Address: 256 Polk Rd 43, Mena, AR 71953
Phone479) 243-9115
HotwireAuto - Fuel Injected Wiring Harnesses
and Chris will custom build you a harness with lengths to match your needs for about $1095. Hotwire Auto can also modify your PCM, (for additional $400+) to remove PATS security and turn off any features you do not want (I think they use HPTuners software).
If you want to modify the 3 factory harnesses I mentioned (14290, 14401, & 14A005) I can do that as well. PM me for details.
Walt
Phone479) 243-9115
Walt
#125
Here are some wiring harness base part numbers by application.
--------------------F150------- Mustang
Engine harness -----12C508 -----12C508
Trans --------------15525 -------14B060
Engine Compartment 12A581 ------14290
Dash Harness------- 14401------- 14401
Chassis (fuel pump)- 14405 -------14A005
Shifter floor--------- 14B079----- 14A005
Column -------------14C685
In a Mustang the 14A005 runs all over the inside of the passenger compartment so it includes the floor shifter and the fuel pump, the Fuel Pump Driver Module, both gas tank senders, etc., along with all the audio, rear lighting, ABS sensors, seating controls, air bag stuff...... crazy harness.
A F150 has a 14A005 too, and it runs all over the passenger compartment but it just contains useless stuff, no powertrain. The floor and column shifters have their own sub harnesses that connect to the 14401 dash harness. That 14405 harness runs from the driver's side of engine compartment where it connects to the 12A581 and then runs to rear of the truck along the driver's side frame rail. It contains the Fuel pump and sender and the Fuel pump Driver Module as well as all the rear lighting and ABS sensors plus a lot of optional stuff like back-up camera and electrically locking diff.
Hope this helps clear up some confusion.
Walt
Walt
#126
I dont mean to promote but There is a person on ebay who says they will disable the pats on your oem pcu, he requires you to send it to him. It may help me but I saw some people were struggling with pats on here. If you search the_parts_fam on ebay he will come up, he has a lot of parts you just have to search for it. By the way I plan to use everything I can for my swap so does anybody have a full list of things I need from a mustang for pats to let me by? And does anyone have any tips for using the factory electric steering from a mustang? Also any tips for retrofiting the mustang dash?
#127
Link to ebay add
PCM Pats Delete Tune 2011 2014 Ford Mustang Computer ECU GT 5 0 Coyote Swap Kit | eBay
#128
That looks promising, I wonder how they can do it and some of the big name tuners can't.
Link to ebay add
Link to ebay add
#129
F100 project
Hi Walt.. I've been reading you post about the project on the swap. I have the same Truck and wondering if there is a way to install the stock coyote motor and trans out of a car or truck and make it work without using the dash to by pass ford's electronic control system? I know a lot of people say it can't be done and there should be a wiring kit available soon so I'm wondering if I can make the stock drive train work now?
Mike,
Cooling fans
Instrument cluster
Hope this helps.
Walt
Cooling fans
Instrument cluster
Hope this helps.
Walt
#130
#131
On 2011-2014 Mustangs the PATS system is in the cluster. So if you want to use a 2011-2014 Mustang powertrain and retain the PATS system you need to use the Mustang Cluster. Or, you can have the PATS system turned off in the PCM so it is not needed to start the engine, and then you do not need to use the Mustang Cluster.
On 2011-2014 F150s the PATS system is in the Body Control Module (BCM) which is mounted in the passenger side kick panel. So you do not need the F150's cluster when doing a swap. If you have PATS turned off in the 2011-2014 F150 PCM, then you can wire around the BCM and delete it if you want (as long as you can live without the other functions of the BCM).
I know that HP tuners can turn off PATS in 2011-2014 Ford PCMs if you send them your PCM. I would not believe anyone that claims they can do this with a laptop or a hand-held programmer, I have never seen this work except when the PCM itself is modified.
I have helped with the wiring on a lot of 5.0L/6R80 and 3.5LEB/6R80 swaps. It seems everyone wants different things included in their swap, so the wiring design is almost always a custom lay-out to reconfigure the production wiring. Please do a lot of planning before you start such a swap, and start with a running donor vehicle if possible!
I will be happy to answer any questions you have, if I can.
Walt
Walt
#132
Thanks sooooo much!!! I've been holding off on buying a motor and trans because I wanted to see if I could use the stock drive train from a f150 or the Mustang. I may be able to buy a salvaged f150 from the auction and use everything!
OK, let's clear this up some.
Walt
Walt
Walt
Walt
#133
My 48Ford F1 is in a SCT dealer shop in Memphis TN having a 2013 Coyote 5.0 truck engine with 6 speed automatic installed right now. I haven't heard of any problems yet as they say they have done this before. I'll update more when I hear the truck running or as I hear of problems. This is the first time for this shop to install the Coyote engine in a older truck but they have done several other swaps in older Mustangs before.
#135
Lightning Motor
I'm not trying to hijack this thread but I have a 2000 5.4L Lightning motor and transmission (4R100) that I want to put into my '49 F1. Are the Tuners able to disable the PATS system in a vehicle this old? I have the full vehicle so I am able to pull off anything I need. Any suggestions? Can I follow the notes from this thread on the Coyote engine or is my 5.4L too different?
