March 2014 BS Thread
I lost power for about a half hour. That was this morning with no bad weather happening. Not sure if it was an accident or a line drop, was somewhat widespread, other family members in different areas of NKY were out of power at same time. I did get the day off from school.
Even as an adult I have a happy dance when getting a snow day. LOL
2014 Upcoming Events
There are a number of non-FTE cruise-ins and shows coming up in Kentucky. You can check them out here:
The Cruise Night Page - Upcoming Events
Apparantly there is a huge monthly cruise-in in Somerset every summer month called the "Somernites Cruise" that has hundreds of cars. It's literally a car show every month. You can learn more here:
Somernites Cruise - Home
Happy cruising.
Happy cruising.
Hey guys, finally have time to post on here again. Been busy with school, baseball, and injury recovery from baseball. I have a situation with my ranger that popped up last night. It has a 4.0 and 4x4 and is an auto. I started it up yesterday evening and turned on the parking lights and fog lights. When I did that the truck acted like it had the key turned off and right back on in a matter of a second. As in engine stuttered, dash lights cycled and then went back to normal. Turned the lights off and back on, did the same, when I got home I turned off the key and the lights. When I opened the door the truck basically went dead. It has no power at all now. Any ideas on what could be the problem? Thanks in advance.
I would check the obvious places first. Remove, clean, and reinstall the battery cables. Check the neg. cable where it's grounded to the truck. Check the pos. cable where it's connected to the relay. You might also check to be sure the cable connectors themselves are making contact with the cable. Cables do sometimes go bad.
The battery could have shorted out. Hooking a battery charger up to it then turning on the lights and seeing if they come on may shed some light on that possibility. If they still don't come on, then do what Ken suggest. Probably the biggest electrical problem that plagues vehicles are faulty grounds. And those ground wires aren't necessarily just the ground cable off the battery. The OBS trucks with the 7.3PSD's are at the point now where a lot of the factory ground wires running from the frame to the body or the motor to the body are giving owners problems. Electricity is a funny thing. It will find the path of least resistance. I've heard of guys having problems with their trucks, and replacing the burnt out bulb in the brake light that's in the back of the cab solved their problem. Actually, if that solved the problem, what likely happened, was that replacing that bulb allowed whatever needed electric, was getting it's ground through that bulb/light fixture. It was back-feeding through the light bulb.
We got a lot of snow and ice here. Finally almost gone now. Road by the house was horrible for 3 days. I cleaned it up a little with my tractor. Snow plow truck finally made it all the way down it and cleared it.
Been tinkering on the Bronco lately along with restoring a tractor for the neighbor. I've been laid off since Thanksgiving.
John, funny you mentioned that. I had a thunderbird and one day it would start but I could not get it into reverse. Three hours later I noticed that as my dad stepped on the brake that the third brake light didn't light up. Took it apart and saw the bulb was blown/shorted out, snipped the socket and car shifted into reverse and everything worked fine. Got back home and hit Airport Ford for a new lamp socket.
