mustang tanks
The only adjustments we made to the Mustang tank installation:
o Charcoal canister - My wife complained that the garage smelled bad. This was wife code for "You better make that truck smell better or else!". We added a charcoal canister to the vent tube & went with a closed gas cap - much better.
o Gas Tank Sending Unit - You need to think through how your sending unit is going to talk to your Gas Gauge. We had modern gauges that required a 0 ohms - 200 ohms signal from the tank. The '70 Mustang tank sending unit sends an 11 ohm - 77ohm signal. So... We liked the '70 mustang sending unit for the fuel pick up & we clipped off the in tank part & welded on a modern universal one that was 0hms - 200ohms.
Don't assume you can fix the Gas Gauge signal issue easily later .... Ask me how I know...
Good luck over there.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
mr56......john's write-up above is the way to go. I also got some help on this a short time ago and listed some links that may be helpful to you. Here is the thread....
https://www.ford-trucks.com/forums/1...and-parts.html
I did the 17 gallon between the frame rails because like yours, mine is gonna be pretty low as well. I wanted the tank to be at least even with, if not higher than the rear axle center section. With the setup i came up with, im a little above the center section. The extra height of the 22 gallon tank with my setup would male the top pretty close to the top of the frame rail, which would interfere with the bed cross member. You could probably take out the bottom spacer and be fine with clearence.
1950f1Mark
24
11-04-2020 10:22 AM
Gibby55
06-24-2014 11:41 AM
blitzkraig56
18
11-23-2002 02:39 PM
