Supercharged 5.4 Superduty - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-27-2014, 06:23 PM
'99 5.4L DUTY '99 5.4L DUTY is offline
'99 5.4L DUTY is starting off with a positive reputation.
I have a 99 f250 5.4l Superduty with 4.10s and a 5-speen manual trans 4X4. i am looking to supercharge it. i want put on the 3.4l whipple for the lightning and the trick flow twisted wedge top end kit and all the other supporting mods ( exhaust/ Fuel system etc).
I was wondering if anyone had any experience with the forced induction 5.4L and what it takes to make a 5.4l be able to stand up to 30 PSI and around 650hp/ft-lb. Bascly i wanna be able to blow any stock or mild built PSD out of the water and have a Badass dune truck
Also wondering if any knows of the cost of a build of this magnitude. Whipple supercharger kit is about $4500 and Trickflow top-end kit is around $3500 (includes heads cams etc.) I currently only $3200 into the truck and Looking to spend less than $12000 on engine/tuning/air and fuel delivery. I plan on doing most of the work myself minus engine machine work and tuning and what not. DO-ABLE??
This is not a right now project. Currently i am solely in the research stage and most likely wont begin purchasing anything for this build for the next 18 months to two years. if anyone has done anything similar or has some helpful information please let me know so i can begin to "pick your brain.
Thanks
Josh
Old 02-27-2014, 06:35 PM
dscabra's Avatar
dscabra dscabra is offline
dscabra is gaining momentum as a positive member of FTE.dscabra is gaining momentum as a positive member of FTE.
Thanks
Josh
30 psi of boost is huge! Most super charger boost numbers on OEM cars tend to be 10-12 psi or less. I would expect that to push 30 psi you will need to beef up the entire rotating assembly. Then once you start making that 600+ h.p., the next weak link is going to be the transmission. You might consider talking to a speed shop in your area, as they can probably give you real advice -- not the speculation that I'm providing.
Old 02-27-2014, 07:05 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Here is a video of a 3.4L Whipple installed on a Mustang. At 17Lb of boost they dyno'd well over 600 RWHP. That went up to way over 700RWHP at 21 pounds.
IMHO, 30 pounds of boost is not survivable with your 5.4L.
Old 02-28-2014, 09:24 AM
wbrook_ford wbrook_ford is offline
wbrook_ford is starting off with a positive reputation.
While the engine is apart, you might consider a forged rotating assembly. The supercharged F150 Lightnings had a forged crank that is good for lots of power.
Not sure how much power/boost the pistons or rods can take.
If I were to spend 10k+ on my 5.4, I'd go high compression, low boost. That way the motor will be torquey and responsive, plus the boost on top will shred
Heck, you could even get a stroker kit for more nuts!
Old 02-28-2014, 03:27 PM
99150's Avatar
99150 99150 is online now
99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.
Rather than go that route; why not just start here
Ford Racing Parts Now Offering 5.8L GT500 Aluminum Block For Sale - EngineLabs
This would be a hell of a starting point
Old 03-06-2014, 09:49 AM
yeah thats gonna be a massive pain in the butt. ill just stick with a 5.4
Old 03-06-2014, 09:58 AM
I am going to put all forged internals in it just dont know what to go with or who makes good components for this engine. I would like to put in aftermarket lightning internals, because im sure somebody has got to make kits for those trucks. looking to go better than stock lightning internals. Also is a SD 5.4 shortblock any different from a lightning short block? or can my block be reinforced to handle the power?
Old 03-06-2014, 10:02 AM
I think all 5.4 iron blocks are more or less the same, save for possibly different mounting bosses for ps pumps, a.c. compressors etc.
Anybody got a 2.3L Whipple on their Lightning or Harley Davidson F-150? Super Duty DJ Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 08-07-2014 10:18 AM
5.4l performance GDog68 Modular V8 (4.6L, 5.4L) 6 01-25-2014 05:07 AM
Whipple Supercharger for 5.4L Super Duty Furian 1999 to 2016 Super Duty 103 09-25-2012 04:59 PM
will the Lightning supercharger Bolt up to my DOHC 5.4 Robsride Modular V8 (4.6L, 5.4L) 10 06-28-2010 07:57 AM
Superchargers on a 4.6 for Improved towing yamahonda41 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 11 01-16-2006 11:28 PM
Tags
5.4 supercharged, 5.4l, gas, lightning, powerstroke, supercharger, superduty, trickflow, whipple
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
