Looking to replace my V10
My friendly neighborhood Ford Dealer called this morning to inform me that someone previously tried to repair the # 7 cylinder with a heli-coil and now the plug won't reach deep enough into the head. They ran a compression test and it was down 40%.
Replacing the plug brought it up to 12% down. They also said the #2 plug won't go in past 2 1/2 turns. I was quoted 20 hours labor to replace both heads. Or 15-17 hours to just drop a fresh one in. My question is what version of the 10 can I use in my double-aught X? I talked a bit today with Wyatt (the parts guy) and he can get a very nice deal for me. What year(s) did Ford finally get their crap together with these bad boys?
I don't have much into it, so dropping 4-6K into it.. I'll still be money ahead as these beasts still get 10-18K used around my neck of the woods .
Thanks in advance,
Miguel..
Thanks in advance,
Miguel..
on
I'd go with a new rebuild but I would sure ask if the rebuild has the new deeper heads. I assume you have the R4100 tranny so you will have to stick with the 2 V engine, but you'll be good to go. That's what I'd do instead of just pulling the heads. This way you get a basically new engine with a warranty.
Thanks in advance,
Miguel..
Thanks in advance,
Miguel..
