Oil pressure test - Ford Truck Enthusiasts Forums
Oil pressure test
Old 02-27-2014, 11:00 AM
judochop judochop is offline
judochop is starting off with a positive reputation.
Oil pressure test
Hey everyone, been here on and off for months reading
about the 5.4 3v since our 5.4 has been sick for quite a while.
We had it at the dealership about a week ago due to severe
knocking/slapping. The computer gave p0012 and p0022 codes.
They replaced both tensioners, oil pump and one of the tensioner
seal.
A few months earlier another dealership replaced both
timing chains and one tensioner which did not fix the issue.
Last week we were told the issue was a bad tensioner seal
that the first dealership likely did not replace when changing
out the tensioner.
On their report last week they reported oil pressure was at 9psi,
replaced both tensions retested oil pressure and got 13 psi.
Everything i've read says minimum pressure is 25 psi,
I asked the service advisor about it and he said it's some "other
pressure test" they did that's not the over all oil pressure
and didn't want to explain what it was exactly.
It seemed to run ok for two days then went back to running like crap.
Its in the shop again....i don't even want to get into it...
but can someone tell me what pressure they were testing that
was 9 psi and then 13 psi ?
Old 02-27-2014, 01:24 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
moved to the Modular V8 section hoping you get better results
Old 02-28-2014, 08:27 AM
Thanks meborder.
Not much response so how about this.
What other oil pressure tests are performed on an engine
other than over all oil pressure?
Old 03-09-2014, 08:03 PM
jesse5 jesse5 is offline
jesse5 is starting off with a positive reputation.
Over all oil pressure was what was tested and it is not enough for proper engine operation. You need an engine. They should credit their repair labor toward the engine replacement.
2004 f150 5.4 throwing p0172 and p0175 Fred Robertson 2004 - 2008 F150 1 03-27-2016 08:34 PM
2006 5.4L, engine noise and weird oil pressure readings Lexrex 2004 - 2008 F150 1 05-05-2015 03:29 PM
2006 F250, 5.4L, 250K miles, Knocks when hot Lexrex 1999 to 2016 Super Duty 4 05-04-2015 10:32 PM
4.6 Timing chain rattle on hot restart mlhebel Modular V8 (4.6L, 5.4L) 10 02-18-2015 09:37 AM
At wits End... P0345 - low oil pressure 06 F150 5.4 Steve_Uzi 2004 - 2008 F150 4 07-25-2012 11:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
