A/C hose seems to kink - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-26-2014, 10:49 PM
Crazyotto1's Avatar
Crazyotto1 Crazyotto1 is offline
Crazyotto1 is gaining momentum as a positive member of FTE.
Ok, I just put a complete new A/C system in my truck, the new hose that comes off the back of the compressor and attaches to the filter drier tank seems to kink a little bit. I didn't feel comfortable and thought maybe the hose was made a little off and went and bought another hose assembly. When I installed the new hose that one also seemed to kink in the same spot. I ended up wrapping some electrical tape around the hose and put a hose clamp over the kink to hold the hoses shape but after it got hot under the hood it seemed to kink just after the hose clamp I installed.
What should I do? Should i pay a shop to replace the hose and charge the system so it will be under warranty if it kinks and burns up my new compressor? Should I buy another hose from a different auto parts store and hope it works better? I'm planning a trip with the family and will be needing the A/C.
Thanks for the help,
Crazyotto1
Old 02-27-2014, 01:56 AM
whitetmw whitetmw is offline
whitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to all
I would have the supplier replace the hose. If it's a direct fit system it shouldn't have a kink.
There is more to worry about than the compressor. Every thing both low/hi sides will have excessive pressure if the hose kinks which can adversely affect seals, condenser, accumulator, evacuator, "O" Rings, ect.
Other option would be to have a hydraulic shop cut and re-couple the hose or purchase an OE hose.
Either way the system will need to be charged.
You've spent both money and time - I don't like to waste either.
Sticking Caliper? Something is holding the truck cstanley44 2007 - 2014 Expedition & Navigator 6 09-04-2016 12:52 AM
Inexpensive windshield washer mod. superrangerman2002 6.7L Power Stroke Diesel 16 01-04-2016 11:55 PM
power steering problems chiefsfootball 1967 - 1972 F-100 & Larger F-Series Trucks 4 02-02-2015 03:53 PM
94 F150 A/C dash vents work intermittently Kapusta 1987 - 1996 F150 & Larger F-Series Trucks 10 09-21-2014 07:27 PM
'83 F250 Cleanin' up the air cleaning system DentyBlueAZ 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 80 06-26-2014 08:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
