Burnt Wiring and no start
The truck is a 1989 F150 with 4.9 6cly.
The problem : I had a bad battery from autozone. While i was hooking it up there a arc and the "fuse wire" running to the alternator melted. I fixed the wire. Now it just cranks with no spark.
Things I've checked: Its getting fuel. My starter relay (mounts to the fender) was bad replaced it. ignition module was bad, replaced that as well. checked my coil and condenser,
HELP?
-23
HELP?
-23
I really don't know were you would start....I think your gonna need a test light and start following the voltage. Check your grounds make sure their not fried. Sounds like a wire that plugs into the coil I know if its not getting a good connection it would just turn over and over with out starting.
Hunter52
104
03-06-2021 06:57 AM
Fistfull of dollars
16
12-26-2017 11:57 PM
Scrapiron66
10-21-2006 12:05 PM
luv2bowhunt
02-16-2004 10:09 PM
