Adding reciever hitch and trailer brake controller? - Ford Truck Enthusiasts Forums
Old 02-26-2014, 09:35 PM
ford141's Avatar
ford141 ford141 is offline
ford141 is starting off with a positive reputation.
My father in law just purchased a 2012 F150 XLT 5.0. It did not come with the factory towing package, but since we have a small dual axle trailer here, he would like to add a hitch and brake controller to the truck. We need to add a 7-pin plug and a brake controller inside the cab, so I was wondering what is the best way to add this to a truck that never had a towing package?
Is there a harness at the back that we can hook up to a 7-pin plug?
On a few of my older F150s they had a plug under the dash that you could plug an aftermarket brake controller into. Would his truck still have this plug even though it never had the towing package?
Old 02-27-2014, 08:11 AM
keyston44 keyston44 is offline
keyston44 is starting off with a positive reputation.
I don't know about the 2012's but my 08 came with the trailer package but no brake control. I bought a brake control and it just plugged in under the dash. Another truck I had didn't have a trailer packaged but had a plug under the rear bumper to plug a 7 pin plug in.
Key
Old 02-27-2014, 01:32 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
There's a little bit of conflicting information about this, but here's the best info i have been able to find:
the plug under the dash should still be there, but the fuses and relays in the power distrobution box probably aren't.
The wires for the 7-way plug should at least be run all the way to the back axle, but may extend all the way back (not sure). you should , at the very least, have the 4-way connector on the rear bumper, most (if not all) do.
My expedition has the factory 4-way plug, and the electric brake wire run all the way to the back, but the rest of the wires that make up the 7-way plug terminate at the rear axle, i would expect yours to be similar.
if you are very lucky, you will find a big round connector under the rear bumper that looks something like this:
http://www.etrailer.com/Custom-Fit-V...id=20121172005
if that's the case, you should be able to buy the plug above, mount it, and install the proper fuses and relays in the fuse box and you are golden .... but i wouldn't hold high hopes in that being the case.
sorry for not being able to be more specific than that. maybe someone who has done it will chime in.
Old 02-28-2014, 01:23 PM
hammer65 hammer65 is online now
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
I purchased a Ford Controller and a harness that goes from the rear axle area to the hitch. This harness has the 7 pin receiver. If you want a hitch, that will accept the 7 pin receiver, you must buy the Ford hitch. or make your own mount for the 7 pin receiver.
I also found that the Blue wire that usually goes from a harness plug ( beginning on the left inner fender)to the 7 pin was not in the harness.
We had to run a new wire. Fuse and relay comes with the Controller.
I am sorry, but I have misplaced the part numbers. I have a 2012 XL.
Do a search, because someone posted the whole process for installing the Ford controller.
trailer, no brakes, no lights, nothing old farm truck Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 12 04-12-2016 10:18 PM
Tow Package? ckal704 1994.5 - 1997 7.3L Power Stroke Diesel 5 08-27-2014 08:29 PM
Tow Package? dvlsmstr Escape & Escape Hybrid 3 08-01-2014 12:26 PM
Adding Factory TBC to truck. Kdr358 1999 to 2016 Super Duty 0 06-28-2014 07:59 PM
Fords trailer brakes saltbranch Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 13 11-26-2013 05:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
