Headers - Ford Truck Enthusiasts Forums
Headers
Old 02-26-2014, 08:58 PM
fords/harleys's Avatar
fords/harleys fords/harleys is offline
fords/harleys is starting off with a positive reputation.
Headers
I am putting together a 351m with 351 cleveland heads. I have a 1976 Valare IFS. Just wondering if anybody has done this, and what headers might fit. I don't want to buy headers and have them not fit. I might have to go with custom headers but they get very pricey of course. Any ideas or suggestions would be appreciated.
Old 02-26-2014, 09:01 PM
That would be on a 1955 F100
Old 02-27-2014, 08:10 AM
48 Steel's Avatar
48 Steel 48 Steel is offline
48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold
I'm using Sanderson Headers PN FC3's on my 351m Stroker in my 48 F1. I have a Jag IFS and it clears fine. Due to my IFS I had to move my motor mounts to the passenger side.
__________________________________________________ __
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness - 3 pedals and a 5 speed"
Old 02-27-2014, 09:05 AM
Branded Branded is online now
Branded is gaining momentum as a positive member of FTE.Branded is gaining momentum as a positive member of FTE.
Is the crossmember under the center of the engine. If not Sanderson makes a center dump block hugger style header. It's the FF5 .
Old 02-28-2014, 09:18 AM
The cross member is close to the center. I needed a rear sump oil pan because the crossmember was in the way. Those shortys look like they could work. I am putting the motor together in 2-3 weeks(waiting on parts).
Old 02-28-2014, 09:31 AM
Sent you a PM on the headers, I have a new set that dump in the center. They are Sanderson FF5.
Old 03-05-2014, 07:09 PM
48 steel why did you go with the FC3's and not the FC'2s. Did the starter get in the way?
Old 03-06-2014, 07:45 AM
48 Steel's Avatar
Quote:
Due to the IFS I have installed I didn't what the headers to interfere with steering linkage.
"If its under control you're not going fast enough"
Old 03-09-2014, 09:16 PM
I did some measuring and ordered my Sanderson FC2's yesterday. Waiting for my pistons(should be here the end of the week). Then have to get the crank, rods, and pistons balanced. I will finally get to build the motor in a couple of weeks. Can't wait!!
351m/400 headers on 460? BigCountry1978 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-16-2016 02:05 AM
will 302 headers bolt to 351w heads ColtonMullis Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 24 06-06-2016 09:39 PM
1986 E350 exhuast headers? mos68x 1968-2013 Full Size Vans 3 02-15-2016 12:19 AM
What headers for a 351 ohbrian 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-18-2014 08:38 AM
Headers doradoguy 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-13-2013 02:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
