Where I work we have dozens of those engines with 4 speed automatics. We went through a real pita when the fuel changed to LSD. For some reason, fuel filters were clogging on almost every vehicle. Major loss of power.
Is that a 12 valve motor? They ain't no powerhouse to begin with....
Yes it is a 12 valve, We are going to try the fuel filter. We not looking to get alot of power out of it, just want it to be able to get up to speed a lot faster & be able to do highway speeds so we are not so slow on the highway
Is it intercooled? Maybe a leaky boot or a hole in the cooler?
Whats the rear axle gearing?
I got a 12V in my dodge and I throw some cetane additive in every fillup. It makes a big difference, especially on the highway. Quiets the motor down a bit too.
I am not sure what rear axle gearing is. We just picked the truck up less then a week ago. But we still have not gotten fuel filter changed yet, that will be getting done Monday.
What RPM is it turning at that 52MPH speed you posted in the 1st post?
Is it blowing any black smoke? (bad clogged air filter)
Have you verified the speed of speedo with a GPS unit?
RPM needle sits on the 20 mark & it says @100 on the rpm meter. No black smoke, but have not checked the air filter yet. Yes i have verified the speed with my GPS.
You mean as in 2000 RPM ? Is this in any gear or just high gear?
