Best engine for hunting
One more useless opinion: The way I look at it, if you have to pull the engine to go through it, you might as well look for a donor truck and just swap in another motor with fewer miles. Might be able to find a cheap donor vehicle with 100k less miles on it.
You can still check the newer engine over (pan rust, oil pump, etc) before you put it in, but you hopefully wont have to worry about damage from a bad head gasket. This also gives you the option to go 300/302/351 if you so desire.
I'd inspect your motor before going donor; there are millions of cars out there that blew head gaskets, had them repaired, and run as good as new.
If the bearings look good and heads are flat, what are we worried about?
OTOH, an EFI 351W is plug-and-play, and is the easiest way to get 100 ft-lb more low end torque
Not the injectors, fuel rails, lower intakes, emissions-compatible manifolds, some sensors....just get a donor engine from the same induction (MAF or SD) and save yourself a lot of headache
Well, with SD, you'll need to swap injectors, with MAF you probably need the injectors that came with the MAF unit, whichever truck it came from.
everything from your 94 will transfer over from a computer and efi standpoint. you have to put longer fuel lines on the fuel rails to make them fit the wider 351 lower intake, but the injectors are the same and good for 300 hp (i would put new seals and rebuild them, only takes a $25 kit and an hour of time). you can even use your current throttle body and it will bolt to a junk yard 351 speed density upper intake perfectly. Ditch the EGR crap and block off the port on the side of the intake manifold and ports on the back of the heads. if you have a good reading 02 sensor you may not even need a tune. more air = more fuel and it just monitors the o2 to get it into the butter zone for power. these mass air ecu units are stupid awesome.
#30
Being your looking at an f150, it's probably a 3.08 or 3.55.
Both require work. If it was me, I'd decide where I want the power band and pick what I wanted to do, then just go for it. If you're going to pull the motor either way, all of the hard work is already done.
