6.0 EGR delete questions
To start, I have a 2005 Excursion with a 08/2004 build date and drive train with a full EGR delete.
The problem I am having is I am getting a check engine light constantly. I have the egr connected still sitting on top of the engine, I use an SCT to tune but even when going through the checklist and turning the egr off it throws a P1334. My Edge insight clears it, and it will not come on until I restart so it isn't too bad. I guess my questions are 1) is the P1334 causing me to loose any power and 2) even with my SCT showing egr off should I still be getting egr codes.
It doesn't appear to be an egr delete issue. It looks like its more of a sensor problem with the throttle plate.
EGR codes that give you a light after they are deleted are normally for flow.
I'm guessing the actuator (throttle plate) either isn't going back to home position or the sensor is not working correctly.
Silentst2000
08-01-2005 04:44 AM
