1988 f150 clutch issue - Ford Truck Enthusiasts Forums
Old 02-25-2014, 04:33 PM
jaltman1984 jaltman1984 is offline
jaltman1984 is starting off with a positive reputation.
hey guys, 1988 f150 4.9 4c4 5 speed . the clutch has recently been replaced for the most part works good, when I first get in it to drive I have about 60% pedal but it shifts fine , then after a while it goes to about 40% its mostly noticeable when im pulling out the clutch releases real close to the floor and stead of the top of the pedal motion. ive replaced the slave cylinder and what knot ... any suggestions comments or ideas? thanks folks
Clutch replacement & other KHflatbed 1987 - 1996 F150 & Larger F-Series Trucks 4 07-02-2015 04:38 PM
1988 f-250 clutch pedal diagram Natcox012 1987 - 1996 F150 & Larger F-Series Trucks 0 04-05-2015 06:22 PM
clutch pedal assembly Natcox012 1987 - 1996 F150 & Larger F-Series Trucks 1 03-19-2015 09:39 AM
Need Clutch Pedal Spring rhoward 1987 - 1996 F150 & Larger F-Series Trucks 0 05-18-2014 03:07 PM
ZF-5 speed 1987 F350 clutch linkage/clutch fork? Tony G Clutch, Transmission, Differential, Axle & Transfer Case 0 07-15-2004 02:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
