1948 Ford flathead oil pressure
Have a 1948 F-3 flathead w/39,600 miles. Miles are not documented but seem to be original given the condition of the truck. The oil pressure w/30 weight starts at 45 but as the truck is driven after 30 min drops to a steady 15-30. There is no oil blow by on the plugs or at the top or bottom oil/crank case vents. The compression check on the left side back to front is 70, 85, 80, 80; on the right side back to front is 85,86,80,85. When first started the truck does have some gray smoke from the exhaust but as driven and engine temp comes up that smoke goes away. Don't know the engine specs on oil pressure, compression or best oil to use, would appreciate any input. Thanks
The compression check on the left side back to front is 70, 85, 80, 80; on the right side back to front is 85,86,80,85. Thanks
Cschneider
08-09-2017 01:48 AM
Sooper Camper
05-24-2013 12:31 PM
AKFORD4x4
09-14-2007 09:36 PM
Deadeye1963
10-26-2004 11:23 PM
