Leveling Kit - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Leveling Kit
Old 02-24-2014, 11:19 PM
Rusty74 Rusty74 is offline
Rusty74 is starting off with a positive reputation.
Leveling Kit
I'm thinking of a 2" leveling kit for my 2012 SD, I did my last 08 PSD and needed a adjustable track bar to center the axle. Will I need to do the same on this truck? I currently installed F350 blocks and shocks on the rear and will put Air Lift bags on if I do the level.
Thanks in advance!
Old 02-25-2014, 04:20 PM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
ya to center the axle you will need either a adjustable track bar or you will need a drop track bar bracket. also to keep everything else in line you will need the trailing arm drop brackets . i just bought the readylift sst level kit. has everything to keep
the front end in line . i got mine with the 5" rear blocks. shock extensions are only required if you go off road or longer shocks. i do believe they sell the kits with out the rear blocks . there called the f350 kit coz they have 4" blocks already, right now they will knock 10% off advertised price if you ask .so you should be able to get a kit for less than 400$
Old 02-25-2014, 06:58 PM
That's what I thought, I didn't think the would be any difference from the 08 front end. If I remember the track bar was around 450.00 from ICON and for that price I may go with a 3" suspension lift, but I'll research the SST.
Old 02-25-2014, 07:47 PM
Amelio's Avatar
Amelio Amelio is offline
Amelio is gaining momentum as a positive member of FTE.
Is the SST kit a 2" leveling kit?
Post up some pics....... I also have a 2012 CC 4x4 and want a little bit of lift.
I always get confused by how they call it a "leveling" kit. I have measured and my truck sits damn near level stock.
So would the kit you bought also be what I would use?
Thanks!
Old 02-25-2014, 08:02 PM
Hotrod70d's Avatar
Its a 2.5 level kit with 4" block its the tow package with the 5" block the 5 wont be quite level slight rake. They make a 3.5 for the diesel if you wanna modify your exhaust slightly for the drive shaft. There web sight has all the diff kits
Old 02-25-2014, 08:06 PM
Amelio's Avatar
Yeah I am not at all interested in modifying my drive shaft.
I want to just bolt on a kit on my drive way without any other mods.
Old 02-28-2014, 02:36 PM
I have found that ICON makes a Stage 4 2.5" kit and has all of the necessary parts to keep everything correct but it will cost around 3,000 just in parts, you get what you pay for!
Old 02-28-2014, 05:19 PM
Hotrod70d's Avatar
ya but i cant see it being worth that much more for only 2.5 inches maybe 8 to 10 inches . im not off roading like 80 percent of the people just lookin for a little more clearance .my offroading is bringing in hay from the field and its hot and dry.
Old 02-28-2014, 05:54 PM
I understand I think the shocks they offer in the kit are what makes it expensive , I would only want to do this so I can gain more clearance when I have tire chains on for hunting but that is only one week out of the year plus it looks good.
Leveling kit 2003 F350 KBOFVA 1999 to 2016 Super Duty 7 10-28-2015 05:39 PM
Daystar 2wd Leveling Kit? DvlRacer 1999 - 2003 7.3L Power Stroke Diesel 12 06-04-2015 12:01 PM
Leveling kit brandon.edwards 6.2L V8 3 03-06-2015 08:45 PM
Ready for a leveling kit, what else do I need? patrickj20 1987 - 1996 F150 & Larger F-Series Trucks 4 11-15-2014 01:10 PM
Eletronic power steering and leveling kit spike1382001 2009 - 2014 F150 5 03-28-2014 03:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
