IFS swap?
Old 02-24-2014, 08:37 PM
brehenkel's Avatar
brehenkel
brehenkel is offline
IFS swap?
Does anyone know what years IFS parts will interchange? I have a 1984 f150 4x4 and need some pieces. Previous owner did not have outer stearing ball joint tight and wollered the hole where it seats. Trying to figure out what years I can use. I know front gears need to match rear and so forth. Would like to go to junk yard and just pull the hole front IFS out. They also broke off all the caliper holding bolts.
Thanks in advance for any help.
Old 02-24-2014, 10:12 PM
RL250's Avatar
RL250
RL250 is offline
80-86 should work. I'm not sure about the next generation (87-96) but I think even they might.
Old 02-25-2014, 06:32 AM
brehenkel's Avatar
brehenkel
Thanks for the reply, does anyone know about the newer generations if those parts will fit?
Old 02-25-2014, 03:11 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
If you get the whole assembly, yes it will fit up to 96. There are a few differences as far as the brake calipers and the 4x4 hubs and how the wheel bearings are tightened. but it's just small stuff that you would only have to worry about if you were changing just the small components out. The whole thing will fit though. And when you go to the store for something small, you may need to remember what year you got the frontend from. Minor things like the caliper retainers, etc.
Old 02-25-2014, 03:14 PM
brehenkel's Avatar
brehenkel
Thanks for the info. Just what I was looking for.
Bootlegger's Deluxe
01-28-2016 07:19 AM
Burple
09-27-2007 07:20 PM
broncman
02-12-2006 09:21 PM
supertruck
10-20-2004 11:00 PM
suprajztwenty
Aerostar
08-17-2004 08:45 PM
Quick Reply: IFS swap?
