Paint ?
Paint ?
A few questions on paint , How much paint will it take to paint a 56 F250 , front clip , cab inside and out , and box [ tailgate , front bulkhead , sides , and fenders . As I will be painting in stages I want to get the paint mixed for the entire truck at one time . Now on color , the truck was a light green [ Maybe sea foam green ] . I was going for a silver with black trim , But that green is growing on me . It is a color that you just don't see , and I like things that are not run of the mill . Anyone have pictures of a stock 56 in the light green that shows , color of wheels , grill ,mirrors , and bumpers ?
Dual liner makes really good "fit in" liners.....might be worth it if you use your truck yet want to keep the bed a factory color.
DualLiner Truck Bed Liner
These fit awesome, we just stuck one in my buddie's 77 F100.
Okay, I'd say 1 1/2 gallons minimum, likely closer to 2.
Personally, I would not shoot a metallic color (silver) in single stage . Too hard to get the flake to lay down evenly. Especially if you are painting individual panels. Plus you can't sand and buff it if you get an "oops".
A solid color will be fine as long as you mix ALL the paint together before you start.
I agree with the metallic, it's hard to paint, especially for an amateur. I've only sprayed a few metallics and it was hard. You have to have a really good compressor that delivers a constant strong supply of air. Also, the metallic will look different from one panel to the next if it's not sprayed all at the same time.
I just sprayed a door and fender repair with silver metallic, the paint came out really nice and glossy but it was about two shades off even though I provided the correct paint code.
Go to this link. It is very useful. You can get the Dupont and Ditzler paint codes from here. Also, in 56 Ford trucks had no Seafoam green, They had Meadow Mist Green (code G)
Here is the link: 1956 Color Codes - Ford Truck Paint Cross-Reference
Here is a 55 in what I believe is Meadow Mist Green, however, in 55 there was no Meadow Mist green, but there was a Sea Sprite green which I think was very similar.
[IMG]<a href="http://s1146.photobucket.com/user/abestauffer/media/ford%20trucks/56meadowmistgreen_zps4d20b0c4.jpg.html" target="_blank"><img src="http://i1146.photobucket.com/albums/o536/abestauffer/ford%20trucks/56meadowmistgreen_zps4d20b0c4.jpg" border="0" alt=" photo 56meadowmistgreen_zps4d20b0c4.jpg"/></a>[/IMG]
Ford : F-100 Pickup 1955 Ford 223ci 6 Cylinder 3 Speed Restored Chro...
Bids 0 $28,495.00
Buy now $33,900.00
Time left:3h 46m
