want factory if possible - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 02-24-2014, 03:10 PM
Philldozer Philldozer is offline
Philldozer is starting off with a positive reputation.
Arrow want factory if possible
i just purchased a used 2012 f250 lariat crew cab 6.2. it doesn't have the heated and cooled seats and i want to know if it's possible to put the factory set up in cause the local ford dealer is telling me konw anyone go through this before?
Old 02-24-2014, 06:11 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
In order to try to get you a better response, I moved your post out of the old thread in which you posted and into its own thread here in the 6.2 forum.
Hopefully you'll get an answer here but you may also consider posting this in the Super Duty forum.
As for the question at hand, to be honest, I've never heard of anyone doing it but feel sure it has been done. Since you've got a Lariat, it should be easier to integrate it into the existing system but you're also talking about having to install the entire system which means the blowers under the seats, associated hardware, wiring, etc. I guess you could find something from a salvaged truck and retrofit it into your truck but I have no idea how much would be involved in doing so.
The heated / cooled seats also integrate with the remote start feature and are activated depending upon ambient temperature at startup.
Old 02-25-2014, 06:05 AM
bikerman2299 bikerman2299 is offline
bikerman2299 is starting off with a positive reputation.
Quote:
So, I know you need to add a few things. The heated and cooled seats work in tandem with the automatic climate control. Check out this conversation, it might help. These gents were also talking about adding heated and cooled seats to their trucks. I hope this helps a bit.
http://www.ford-trucks.com/forums/12...-2012-xlt.html
Old 02-25-2014, 09:38 AM
Big Vic Big Vic is offline
Big Vic is starting off with a positive reputation.
If you are lucky, there MAY be a wiring harness under your current seats that would be plug in for factory heated/cooled seats...BUT, then you would also need to upgrade the dash climate control unit, buy new perforated Lariat seats which include all the necessary heat/cool gizmos. There may also be computer flashing needed to run the seats properly.
Sounds incredibly expensive to me. There are aftermarket heated seat kits available that would be cheaper and easier to install.
Old 02-25-2014, 12:05 PM
Thanks for all the good advise I think im going with just the aftermarket set up sound expensive to go the other route. Has any one done any mods to the 6.2 to get better fuel mileage and power?
Old 02-25-2014, 12:06 PM
Also thank you powerstroke 72 for moving my tread to the proper place
Old 02-28-2014, 04:47 AM
These trucks are pretty up to date with fuel mileage and such. I added an exhaust system, an intake, and a tuner. Total, I saw about a 1mpg increase. For the money, that isn't much. You just have to keep in mind the truck is HEAVY! Personally, mine weighs in at just over 6700 pounds with about a half tank of gas. I wish you luck though.
Old 03-02-2014, 06:57 AM
thanks for all the advise going with the aftermarked heated seats and not getting the cooled. as for the mpg not a lot more for the amount of money to get one more mpg i know when of bought the beast it wasn't for good mpg but always lookimg to improve were possible thanks guys.
Old 06-11-2014, 06:44 PM
-brent's Avatar
-brent -brent is offline
-brent is starting off with a positive reputation.
Where are you looking for aftermarket heated? I would like to try that in mine...
2016 F150 factory bed lights Drew1295 2015+ F150 7 02-13-2017 12:16 AM
How to get factory window sticker Walwal44 1987 - 1996 F150 & Larger F-Series Trucks 3 07-05-2015 07:29 PM
Radio with Navigation upgrade CPL_Guimonster 1999 to 2016 Super Duty 3 03-03-2015 11:22 AM
Newer nav older truck Broncoguy89 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 08-05-2014 04:45 PM
Fender Flares T. Banning 1999 to 2016 Super Duty 6 07-27-2014 06:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
