Ficm
Old 02-24-2014, 04:07 PM
Corey2001's Avatar
Corey2001
Corey2001 is offline
Ficm
Hello everyone I just changed out my ficm an now I'm getting a 0279 code does anyone happen to know what it means?
Old 02-24-2014, 04:13 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
P0279 Cylinder #7 Injector Circuit Low. FICM detected an open the injector circuit. Injector circuit open or defective coil.
Where did the FICM come from and why did you have to change it?
Old 02-24-2014, 04:19 PM
Corey2001's Avatar
Corey2001
It came from ED I changed it to put the atlas 40 nothing was wrong with mine
Old 02-24-2014, 05:00 PM
npccpartsman
Then as the code says I would check for a broken wire or defective coil. It can be accomplished with a DVOM.
Old 02-24-2014, 05:02 PM
Corey2001's Avatar
Corey2001
The back plug had one broken clip on the one side would that have anything to do with the code?
Old 02-24-2014, 05:04 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Yes it could. Let me guess #7? Driver side rear?
Old 02-24-2014, 05:08 PM
Corey2001's Avatar
Corey2001
I mean the back plug on the ficm
Old 02-24-2014, 05:15 PM
9228.bobcat
My mistake. Misunderstood you. Usually if it is a plug it would be more than one cylinder. But I guess anything is possible. Try pushing it all the way on and zip tie it on.
Old 02-24-2014, 05:22 PM
Corey2001's Avatar
Corey2001
I just bought some zips ties going to try that tomo after work
Old 02-24-2014, 05:43 PM
npccpartsman
If you want to check wire continuity while you're there here's a pinout of the plugs
Maleficent
10-19-2017 08:45 AM
78fourby4f250
1997 - 2003 F150
07-08-2015 10:49 AM
Gothere
09-04-2014 05:28 PM
KansasFlyer
10-31-2010 04:31 PM
Baciagaloop
03-09-2010 05:19 PM
Quick Reply: Ficm
