1990 f250 351w engine swap
I am swapping a 1994 351w into my 1990 f250 to replace the ceased 351w already in it. I am now swapping parts from the 1990 to the 1994. I was told all i needed to swap was the wiring harness, and the distributor as with the gear. i am noticing the 94 ignition coil has one less connector, so should i swap the 1990 ignition coil over to the new motor? thanks for your help.
-Ryan
-Ryan
topdawgtrkr
03-01-2010 12:07 AM
