passenger floor wet
Old 02-24-2014, 01:36 PM
keisha9's Avatar
keisha9
keisha9 is offline
passenger floor wet
Having condensation under carpet between floor metal and carpet pad. I've been looking for leaks. No luck. Why is this happening! It looks more like condensation than a leak. . well, I guess I'll go look again. ..
Old 02-24-2014, 04:07 PM
danorules's Avatar
danorules
danorules is offline
Common problem with 2 potential causes. Either the third brake light is leaking, or the a.c. condensate tube is clogged on the firewall.
If it's the brake light, clear silicone will do the trick.
If the condensate tube, there is a tsb to fix it. All it needs is a blast from an air compressor and a 90° elbow
Old 02-24-2014, 05:56 PM
keisha9's Avatar
keisha9
keisha9 is offline
take off inner fender to get to it?
Old 02-25-2014, 08:00 AM
tooldad's Avatar
tooldad
tooldad is offline
Replaced my 90 Deg elbo from underneath truck. Removed nothing.
Another reported leak path was through seam or pinhole in front passenger door weather stripping at bottom of door. Not been long since I saw that post.
96 eddie
2009 - 2014 F150
12-30-2020 11:35 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
19
09-13-2017 12:54 AM
trent_44
01-24-2012 03:23 PM
Javelin389
1997-2006 Expedition & Navigator
09-07-2006 07:34 AM
fordwel
07-21-2001 02:50 PM
Quick Reply: passenger floor wet
